Scanning to Mac
  • copiman
    • Sep 2011
    • 861
    Scanning to Mac
    In talking with someone about scanning to a mac, they said that if the mac had the software that allows the mac to run a windows operating system you could set up scan to PC. I'm assuming they are saying that you load a windows os on the mac and flip flop between the two. Not sure. Anyone know more detail on this
    This mac is 10.8. I was wondering if the 10.7 driver would work for printing?
    The copier used to scan/print is a Panasonic DPC 354.
  • HP:guy
    • Feb 2013
    • 279
    Re: Scanning to Mac
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      Re: Scanning to Mac
      If the device uses SMB scanning then you can follow my advice here: http://www.copytechnet.com/forums/ri...tml#post322532 and
      http://www.copytechnet.com/forums/ky...tml#post332905
      • copiman
        • Sep 2011
        • 861
        Re: Scanning to Mac
        Thanks for responding HP:Guy & Ruben. I have found a solution for scanning. The DPC 354 comes standard with a hard drive. There are 12 scanner boxes in the machine which you can rename. You can scan to the hard drive then web into the machine and retrieve the document from the box you scanned it to. Pretty neat.
        Not sure yet about the print driver issue.
