Printing Defaults not Replicating to Clients
  • Mooseface2r
    • Jan 2011
    • 114
    Hi, i am having a problem with the above.
    We install a printer driver on server 2003 for the Konica c220 and set the printing defaults to grey scale.
    then i connect to this shared printer. but the grey scale defaults are not set like they have been on the server.
    has anyone got any ideas what might be causing this. ive installed and shared drivers many times with defaults before but this one isnt playing ball for me?
  • DavePo
    • 305
    Re: Printing Defaults not Replicating to Clients
    I have never seen color machines that were shared have the default be B/W and the default be shared out to clients. As far as I can tell printing preferences always are open to each client.
    • Ricohguy
      • Sep 2012
      • 48
      I have had success with setting both the Printer Preferences and the Printing Defaults under Advanced. Also, if the server is 32bit and the clients are 64bit, you will need to use the Universal Print Driver to push the profile down correctly.(At least with Ricohs)
      • Ceechtay
        • Sep 2011
        • 158
        Exactly where are you setting the defaults? Through Printing Preferences or through the Printer Properties' Advanced tab? If you use the Printer Properties' Advanced tab and click the Printing Defaults... button, make the settings there and it should hopefully transfer those settings.
        • speedtek
          • Apr 2013
          • 46
          This is definitely the correct method to get b/w defaulted on the clients. I've had instances where the default only translated to new connections, meaning you may have to delete the printer from the client and reconnect it to the share.
          • TheOwl
            • Nov 2008
            • 1732
            Just of late, this seems to be an issue with Konica Minolta print drivers.
            I don't know what they are doing different, but this issue is also happening on other Konica Minolta models as well.
            In some cases, I have had success with a different version of print driver.
            • symtech
              • Oct 2016
              • 6
              I know this is an old thread but I'm having this exact problem when I recently upgraded the driver on our KM-C454e. I've tried just about everything I can think of including installing the old driver... which of course is also exhibiting the same issues now. Did you ever find a solution?
              • Santander
                • May 2009
                • 768
                What OS are you installing the driver on? Win10 and Server 2012 on have a protection built in that prohibits changing core system files unless you right click on the driver install program and choose "run as administrator" [even if you have admin rights]. It will ignore changes to dll files and registry entries unless you do this. Try un-installing the driver and re-installing using the run as administrator using an admin account and see if that does not help.
                • symtech
                  • Oct 2016
                  • 6
                  Thanks so much for replying.
                  Yes. I'm running Server 2012 with Win10 clients. Unfortunately the latest driver for the Bizhub c454e does not include the Printer Installation program. It's just the driver itself. I installed it through Server 2012's Print Management. When we got the machines 6 months ago and installed the old driver... everything worked fine. It wasn't until I recently updated the driver that the issue has presented itself... and now even rolling back to the old driver does the same thing now. So frustrating.
                  Although I couldn't try your recommendation I appreciate you taking the time to try and help anyway.
                  Thanks again.
                  • Santander
                    • May 2009
                    • 768
                    OK, so you had to use the add print function in the server. After you installed the print driver did you right click on it and select run as administrator, then select properties and set the defaults there? The same rational applies. If the old print driver was installed a while ago, the WinServer updates would not affect the files already installed, but would any new driver files. Even a WinServer 2008 R2 install with all the updates will exhibit this problem. It is worth a shot.
                    • symtech
                      • Oct 2016
                      • 6
                      I added it through Print Management (see screenshot). I don't think there's any method to choose Run as Administrator.
                      • Santander
                        • May 2009
                        • 768
                        If you can not right click on the printer driver and get a run as administrator then the username and password you used to install it does not have admin privileges, I do not believe you have a driver problem but a permissions problem. Does this customer have an IT dept? They should be able to get this corrected if they are good. If they do not have an IT dept then someone should have the admin username and password to set this up.
                        • symtech
                          • Oct 2016
                          • 6
                          I am the IT Dept. I've been installing printer drivers on servers/clients for 15 years and I've installed three network printers on our current environment without any issues the same way every time... including the printer that we're experiencing issues with. I've always logged in as Admin before installing (I did right-click and Run as Administrator by the way just now and that didn't work). It wasn't until I upgraded the driver that this bug presented itself. I say bug because it seems to be somewhat of a common issue online in regards to BizHub printer drivers.
                          Thank you for your help though.
                          • symtech
                            • Oct 2016
                            • 6
                            Not really sure this is a solution, but after installing the functional (albeit non-preferred) PCL driver (instead of PS) the settings seem to be replicating now. I also had to change the printer name and share name. Also it seems settings will replicate only once. If changes are made on the server again the client doesn't download the settings unless the machine is restarted. Weird. It's functioning within tolerance levels at this point.
                            • ApeosMan
                              • Nov 2009
                              • 183
                              For those user's who're running Windows 10 AE (Anniversary Edition) the default print driver settings are not replicated from the server. Here are a couple of support links:
                              https://support.microsoft.com/en-ie/kb/3201130
                              The easiest approach appears to be to have someone with admin rights apply the default settings on a Windows 10 AE PC and then this way the default settings will be applied to all Windows 10 AE PC's.
