Sharp AR-M205 Usb Cable Scanning....
  • Kyocop
    • 69
    Have the above model that a client wants to use for scanning from a laptop (direct Connect via USB 2 to USB 1.1) and I have found no way to make that happen. This is not on a network so no assigned IP addresses and even when the laptop sees the model, I can find no drivers via sharp nor anyway that Sharpdesk (a network scanning tool) can make it work.
    The laptop was running XP, and I have followed the Software Setup Guide but still no success. Was going to try windows 7 next, but...just frustrating.
    Any help would be appreciated.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp AR-M205 Usb Cable Scanning....
    You need the Sharpdesk GDI version.
    • Kyocop
      • 69
      Thank you for the response. Did try the GDI print driver in the list (still would not print) but not sure if I downloaded a GDI version of SharpDesk. Will look in that direction. And of course I had disabled any types of virus protection firewalls ect.
      • brewster67
        • Jul 2011
        • 167
        If you go to IDNC site the Sharpdesk GDI is under the Software Library.
        • Kyocop
          • 69
          Downloading now.....wonder if it still has that very cryptic license key that SD 3.2 has (). This is an offsite installation so I hope it works. Sorry for the ignorance....but what does the GDI stand for?
          • ZOOTECH
            • 3375
            Graphics Device Interface - Wikipedia, the free encyclopedia
            • Kyocop
              • 69
              Downloaded the GDI package, went to the install, still failed. Lol no button on Sharpdesk to search for the scanner (like the networking version), although the computer can see copier. I followed the instructions on the software installation guide but still no dice.
              If someone has the time to let me know what steps I should be taking, would be much appreciated.
              Thanks very much.
              • faxman28
                • 436
                button manager is needed and the copier needs erb7(electronic sort board) installed according to spec in service manual.
                • jobert
                  • Jan 2011
                  • 49
                  Hey..try to download in this site Sharp Australia Support. I tried that before. Works on me.
                  • jobert
                    • Jan 2011
                    • 49
                    Download this two drivers: MFP Driver (Integrated Installer for GDI/SPLC Printing & Scanning via USB)
                    and
                    ARM160/205 Button Manager A - (required for USB scanning).
                    • Kyocop
                      • 69
                      Thanks for the new directions, will try again today.
