Whoami
    • 8139
    Whoami
    If you are ever uncertain what is the correct User Name on a PC when you are trying to program scan to file, go to the Command Prompt and type in: whoami .
    Try it on your PC!
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: Whoami
    Good one. Cheers mate. This will come in handy.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • dickierock
      • 252
      Re: Whoami
      Tried this on an XP device,didn't work but "echo %USERNAME%" gives you the same result.
      • Choro1dal
        • Jun 2008
        • 176
        Re: Whoami
        A couple of excellent tips.
        Hopefully you may find running the set command from within the command shell equally as useful.
        (c:\>set)
        • blaze2000
          • Sep 2010
          • 232
          Re: Whoami
          good stuff, the set command saves so much time when you need to determine 32 or 64 bit os
          • Dustin(WOP)
            • 223
            Windows key + R type msinfo32 this will give user name pc name x32 or x64 all in one place!!!! I use it all the time. Win8 hides everything but it cant hide run commands!!!
            • RickB
              • Sep 2010
              • 5
              Re: Whoami
              Command Prompt > "net config workstation" everything except password
