Can't scan hostname
  • JR2ALTA
    • Feb 2010
    • 2033
    Can't scan hostname
    Yes I know about dns
    when scan to hostname positively, absolutely won't work, what's the reason?
    Cheap router? Computer configuration?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Can't scan hostname
    Are the devices on the same subnet? If not then direct resolution will not work, you will need a router or DNS server to resolve the name. Instead of using hostname; why not set to static IP outside of DHCP range?
    • RRodgers
      • Jun 2009
      • 1947
      Just had a newer Konica instlal do this. I would blame machine firmware.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        some low end Konica's need the hostname in all caps for hostname scanning. Otherwise dns configuration or blocked ports/firewall issue. Try the last dns entry as 8.8.8.8 and see if that works. Otherwise dhcp mac reservation so computers always have same IP.
        • xeroid
          Document Technologies Pro
          • 148
          DNS cannot lookup/resolve hostname if IP works and hostname doesn't. Ensure your DNS configuration is good. Try a temporary DHCP setup on the device to see what the DHCP service at the router configures the device DNS and domain name if there is one.
          • RollingROARANDA
            • Nov 2012
            • 72
            If they have a cheap router, I'm willing to bet DHCP reservation is your fix. And 7 out of 10 times, that NetGear or Linksys is using the factory default password. You do this, and they won't call back again unless they change routers
            Computer configuration? This is sounding more like the guy with the cheap router. I've caught this type of customer naming his PC and laptop both John-PC, so we can't vouch for his "configuration".
            If it's a big outfit, when I'm on that call with their IT guy, one of my tests is to plug in IP addresses instead of hostnames; if it's the cure I let them figure it out from there.
            • MattL
              • Apr 2012
              • 97
              If you are scanning to a hostname on your network 8.8.8.8 will not work, you will need the IP address of your internal DNS for it to work.
              8.8.8.8 is an external DNS and will not pick up stuff on your network.
              The other thing is to replace the hostname with the IP address of said hostname, that will more than likely work.
              • rthonpm
                • Aug 2007
                • 2859
                What type of network setup is it? Domain? Workgroup? Something else?
                • techsass
                  • Dec 2010
                  • 248
                  I had the same issue at my last call today. It was a pretty big network at a hospital and all 3 DNS connections were successful, but it wouldn't resolve the name until I entered in the WINS server. I usually just put in the 1st DNS server I get off of DHCP under WINS, but since ipconfig had a different server for WINS I used it and my scans started working.
                  • ApeosMan
                    • Nov 2009
                    • 183
                    If the hostname of the server/computer is in a different subnet or VLAN then you need to enter it into the DNS, so the DNS server can actually resolve it to an IP.
                    If you're using a Windows Server as your DNS then once the hostname is in the DNS you may then need to use it's FQN (fully qualified domain name), e.g. hostname.local or hostname.company.local depending on how things are setup there. The I.T. rep should do this and provide the relevant info.
                    If the customer just has a hardware based DNS like an all in one router/modem/switch then enter the hostname into the DNS of that device, so the DNS server can then resolve the hostname request.
                    If everything is on the same network and there is no other subnet or VLAN then I'd still suggest entering in the hostname into the DNS if you're having issues.
                    Hopefully this makes sense
                    • ApeosMan
                      • Nov 2009
                      • 183
                      I'm surprised places out there still use WINS. I come across them too time to time. DNS has made WINS a bit redundant now.
                        • 37520
                        Two things I have encounter when setting up scan to folder.
                        1. Make certain the correct domain name is setup on the MPF. If not, the server will not allow connection.
                        2. The first DNS must be the primary domain DNS. If the customer has a secondary DNS the use it as the second DNS. 8.8.8.8 can be used as an additional DNS if scan to email is going to used.
                        As for subnets, if the first two octets are the same, set the subnet mask to 255.255.0.0. I have a school district with ten locations not counting the server location. They have multiple 2008R2 servers at the server location. Print server, file server, DNS, and DHCP are the ones I am aware of. All print drivers are installed on the print server. All scan to folder is to the file server.
