Print Data/Packet Capture Troubleshooting Thread
  • unisys12
    • 489
    Do you have a printer giving you problems? Do you have a data/packet capture of a printer issue but you do not know what your looking at? You have come to the right place! Upload your file here and we will help you out. There are plenty of people here at Copytech.net that can troubleshoot your issue.
    Please, if you do post a capture, edit the capture so that no private information is exchanged between you, your client and Copy tech.net. Copy tech.net, will not be held responsible for private information being exchanged within its network. It is the technicians responsibility to make sure that all your customers info is held secret and confidential. If any of us notice that you have not edited your post, we will notify the admins of the site and request that they delete your post.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
  • DocuSystems
    Service/IT/Integrator
    • Jan 2007
    • 54
    Bizhub 350 on a W2K3 Domain
    This one has me scratching my head!
    Can't print or open internal webpage on the client's network. MFP has a static IP. I can ping, login to ftp, and scan to SMB. As soon as a print is sent, the machine displays the usual ! in the bottom right of the display, but never goes to the printing screen. At this point, scans (either for faxing or SMB scanning) stop working as well. I think the NIC is locking up. I've done the hub/packet capture thing, and noticed that if I remove the customers network cable and boot the MFP, all works as it should. Printing, scanning, etc. If I then momentarily connect the customers network to the hub, wait a couple of minutes, and then disconnect their network and try a test print, it fails the same way as if it were still connected. IP in use is free on their network, so no conflict there. Web Page responds with a 500 Internal Server Error. Even tried DHCP enabled with no joy. Also tried running to another network jack connected to a working workstation in a different room, same failure.
    Gonna look at the packets and try to learn how to decipher what I see, but wondered if anyone has seen these odd symptoms before. The clients IT guy says he can't find anything, but then he didn't find the bad cable either... still no luck after replacing the cable, btw. Same symptoms. I'm pretty sure the problem is with their equipment, but it's the "I've got HP printers connected to the same switch with no problems" catch 22!!
    I've posted this in another thread, but I need some help deciphering these packets, so I am posting them here.
    Last edited by DocuSystems; 06-04-2008, 04:30 PM. Reason: Attachments needed to be added...
