Unable to save files through web image monitor "mp4500"
  • edwin206
    • Mar 2012
    • 36
    Hi,
    I am copier tech but with very low professioncy in networking related issues.
    It is MP 4500 with PRINT/SCAN options.My customers scan some books through Document Server and save them in machine.Later he tries to save those material in his laptop through "WEB IMAGE MONITOR" but do not succeed to do so.Files are shown at computer screen in WIM.He is unable to save the files.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Unable to save files through web image monitor "mp4500"
    The machine requires the "File Format Converter" option, which is NOT standard.
    It's probably the least ever ordered option.
    I know, it looks like the files are downloadable, but they are not without the option being installed.
    • edwin206
      • Mar 2012
      • 36
      Thanking you the prompt and valuable reply.
      Would you please guide me about the file format converter.Please write down some converter's nme(software name) and I will try to arrange .[
      REGARDS.
      QUOTE=KenB;382080]The machine requires the "File Format Converter" option, which is NOT standard.
      I know, it looks like the files are downloadable, but they are not without the option being installed.[/QUOTE]
        • 37503
        Information on File Format Converter
        File Format Converter Type B; EDP Code 411400; Product Code B609.
        Once the FIle Format Converter is installed, scan using the scanner function which allows you to specify which format to use, PDF or TIFF.
