Greetings all.
Under Network Settings > TCP/IP Settings, the only fields available on this ImagePress C1 are Certificate Settings and Proxy Settings. There is no TCP/IP field to enter an IP address. There is also a message at the bottom of this window that shows "Check the network connection". I have verified that the network cable to the machine is not at fault. Any advice to the next step of troubleshooting?
Thanks.
Thanks.
