Internet Faxing and dumping the phone line ?
  • Simons
    • Jun 2008
    • 490
    What are some of your favorite options? A scanner is available and the question is, if we quit the phone company, what service would you hire to handle incoming and outgoing faxing online ?
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Internet Faxing and dumping the phone line ?
    Remember that internet "faxing", is not faxing, it is email.
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      I've not seen too many no dealt with, but Rightfax seems to be most common.
      • Simons
        • Jun 2008
        • 490
        looks like Ring Central wins.
        • MattL
          • Apr 2012
          • 97
          Why not get rid of fax and just use scan to email, we got rid of all our fax lines years ago.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Not every place can. Because it's still viewed as "secure" or legal verified transmission. The fax services are great because if you have multiple machines you can get rid of the landlines tied to them, and save on the cost.
            • ApeosMan
              • Nov 2009
              • 183
              'Internet Fax' never really took off and is dated. Essentially it's faxing over TCP/IP via an SMTP server or SMTP reception. If the other IFax enabled device is on the same LAN it can also bypass the mail server as long as the setup is correct on both devices and SMTP reception is in use.
              If the customer doesn't want a fax line anymore I'd suggest an online hosted fax solution where they can fax directly from their computers and receive the fax via e-mail or FTP etc
                • 37639
                I have used eFax in the past. You get a fax number for others to send faxes to you and software for sending and receiving faxes. You can also receive the faxes as email attachments. When I was with a transportation unit in Iraq in 2005, I and a number of other senior NCO's had eFax accounts. When soldiers in the unit needed paper work from their home units, it was 10 days by mail or as soon as the sender could get to a fax machine by eFax.
