Installed new at customer location. They have two odd paper sizes that they use. 8.5 x 13.25 which works fine and also 8.5 x 12.5 which does not work.
Custom sizes were created on computer in the forms so that it can be selected by the driver. Also set up custom sizes on the copier.
Using UFRII driver. All paper size settings set to correct custom size and manual tray select. It give an error which I attached indication that OFI paper is needed.
The 8.5 x 13.25 works fine. Currently as a workaround they are printing to this size and trimming it off.
Also tried a PS3 driver no difference
Sent from my DROID BIONIC using Tapatalk
