Ricoh mp 2550B web Monitior not working
  • COPIERMAN
    • Jun 2009
    • 559
    Customer has a ricoh mp 2550 that they can use web monitor to make changes in address book. Now on the mp 255ob this feature doesn't work. Is something turn off in service mode or what do I need to make web monitor work on copier. Copier came from a government office.
    • 37483
    Re: Ricoh mp 2550B web Monitior not working
    The MP 2550B is a basic copy only machine. The connector is there for a network cable but the firmware is not. It can be upgraded to print/scan by adding the Printer Scanner Unit EDP 414401. There is also a Scanner Option and a RPCS Print Option. If it has had one of these options installed, then check SP 5985 and 5885. To tell if it has one of the options, check if the print and/or scan button is on the operation panel and works.
    • COPIERMAN
      • Jun 2009
      • 559
      Copier has all features and they all work with no problem. I update network firmware so that can scan to a windows 8 also. its just the web monitor that doesn't work.
      • skynetto
        • Sep 2012
        • 257
        Check 5885-20
        Bit switches should be all to 0
        • COPIERMAN
          • Jun 2009
          • 559
          Originally posted by skynetto
          Check 5885-20
          they are at zero. copier came from goverment and had all the system lock up were doc server could not be use and hard drive with overwrite protection did a memory all clear 5 801 which gave use option to use doc server on copier and remove overwrite protection
          • skynetto
            • Sep 2012
            • 257
            When you are tryin from pc to access wim what error are you getting?
            Also check this.
            http://www.copytechnet.com/forums/sh...rinting-issues
            • COPIERMAN
              • Jun 2009
              • 559
              I'm getting this message from fire fox web browser firefox cant establish connection to the server at Ip address
              • COPIERMAN
                • Jun 2009
                • 559
                I try the telnet and says could not open connection to the host on port ip address connect failed
                • skynetto
                  • Sep 2012
                  • 257
                  does ping work?
                  Have you reset settings to default as per link I've send to you?
                  • COPIERMAN
                    • Jun 2009
                    • 559
                    yes i can ping it. I can print, scan to folder/ email/ and use doc server. It like the web monitor is either missing or turn off i try clearing it by link but says sever cant be found.
                    • skynetto
                      • Sep 2012
                      • 257
                      Is this firmware installed?
                      Firmware WebSupport ver. 1.54
                      It seems like it's missing wim firmware at all.
                      • COPIERMAN
                        • Jun 2009
                        • 559
                        20140324091023641.pdf
                        • COPIERMAN
                          • Jun 2009
                          • 559
                          I sent a pdf of firmware list showing it has it. i am going out now in field. I do appreciate your time with this.
                          • CRISTIAN MULLER
                            • Feb 2013
                            • 145
                            colud be proxy settings on browser, disable proxy on browser and try.
                            • rthonpm
                              • Aug 2007
                              • 2853
                              Could be a couple of things:
                              1. Try the secure version of the web page. If it came from a government office, a non-SSL web server like this would get flagged as a potential vulnerability.
                              2. Check the in depth security settings in User Tools: if you push the machine up to Level 2 I think the web server is deactivated.
                              3. make sure there isn't something goofy in place like a subnet or firewall that blocks direct access to machines registered as printers, or other than regular computers. I had a customer's network engineer get a little too cute lately and segment off everything by function.
