Scan to USB Hard drive?
  • mungooz
    • Dec 2007
    • 34
    Does anyone know how to or if its possible to scan using SMB from a Konica Bizhub series copier to a hard drive that is attached to a workstation via usb?
    The customer is in an all Mac environment as well. I tried setting it up but I'm not sure exactly about the path as the error message I was getting was "No specified folder."
  • konisolver
    System Engineer
    • Oct 2007
    • 137
    Is it 10.5? Sounds like you have all the rights correct all you need to do is point it to the folder ( users\home\scans) if you already have WFS and SMB enable on the mac you can search from the bizhub and added to the one-touch.
    • nmfaxman
      • 1702
      Sorry, only printing is allowed via USB.
      Put it on a network via peer to peer.
      Maker sure appletalk is enabled.
      • Parlett316
        • 21
        I'm pretty sure you can't share USB drive over the network. I've tried to share my Western Digital 500gig USB drive and access files on my modded Xbox with no success.
        • fausto1981
          IT Technician
          • Dec 2007
          • 145
          You then plug your hard drive into the network storage adapter, and you'll be able to access the files on that hard drive from any computer, wired or wireless, on your network. If you're looking for a new hard drive, the solution is even easier: a network-attached storage (NAS) drive. You can plug these drives straight into an Ethernet port on your wireless router and share files over your network. Many of these NAS drives have USB ports, so you can easily expand your networked storage by plugging in additional USB hard drives.
          Sharing external USB drive over network [Archive] - The macosxhints Forums
          • knightfall
            • Jul 2006
            • 633
            I believe that only the local hard drive is allowed not mapped shared or usb that is for the pc and I think for the mac since it is smb'd from the controller and not the computer.
            Get your facts first, and then you can distort them as much as you please.
