CF3102 Fiery X3e+ Scanner problems
  • wjbzone
    Hello,
    My first post here. I am trying to get my scanner to work on my Windows 2000 networked Minolta CF3102
    Have been trying everything I know to get it to work. Manuals do not match my screens on the panel or pagescope.
    1.
    How do I set the destination so I can scan to a file (that I can access on my computer)
    2.
    I installed the twain driver and am having problems:
    When Importing from Photoshop, I get a dialog box :
    Select device 0.0.0.0
    I enter the IP for the scanner and get scanner not found
    I can ping the ip and get a reply
    Any Suggestion appreciated.
    Bill
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    There is an FTP utility that you can DL from the Minolta site. It seems to work best on most networks with very little fuss. I've not had much luck or experience with the twain driver and I don't think SMB is an option.
    • wjbzone
      FTP scan setup
      I searched the minolta site for a ftp utility. It finally led me to Filezilla.
      I installed Filezilla ftp server.
      1.
      Filezilla wants me to connect to a server before I do anything else.
      Is the server my workstation (127.0.0.1) or is it the fiery (192.168.1.3)?
      I assume I should use port 9100.
      2.
      The manual for the fiery says to register the ftp server using pagescope. My version of pagesope does not have a way to register ftp under the network tab. It does have a LDAP setting page, How can I register the ftp server?
      • cobiray
        • Mar 2008
        • 1199
        PM sent
        • wjbzone
          Thanks cobi
          Got the utility, Uninstalled filezilla, Installed new ftp utility, The ftp Utility settings :
          TCP port 21
          Root folder e:\7
          FTP User anonymous
          The ftp utility seems to work fine. From the command window on any workstation in my network, I can put a file into the root folder.
          My problem now is registering the ftp on the fiery controller. This is what I am seeing:
          On WebTools, (if I do not log-in), the Scan tab , One Touch Key Registration shows Index 1 thru Index 7 and Group
          -select Index 1
          -click in first cell under index 1 at bottom of screen
          -Set Destination to Scan to FTP Server
          -click next
          Scan to FTP Server screen requires this info:
          Destination Name (I tried "wjb")
          IP Address ( I entered IP of the workstation running ftp utility)
          User name (I use "anonymous" as set in ftp settings)
          Password (I use "pass" as set in ftp settings)
          Directory (I use "e:\7" as set in ftp settings)
          Use Proxy (No)
          Notification Address (I do not know what to put here I tried "wjb" the ip address)
          -click Create
          the screen returns to the One-Touch Key Registration and nothing has changed.
          I try to scan on the CF3102, and select index1, It tells me "address has not been typed" (does not matter if mode is email or internet)
          I tried all of the above with the TCP port set to 9100, and got same result.
          Am I missing something?
          If I log-in on the pagescope light (webtools) I cannot get to the screen to set the index1 as above, it will only let me delete the one touch keys.
          Bill
          • B0265
            • Jan 2007
            • 718
            Originally posted by wjbzone
            2.
            If you have a Fiery Controller, you must install the Fiery Remote Scan to be able to do a Twain scan.
            • cobiray
              • Mar 2008
              • 1199
              It sounds like you aren't hitting ok at some point to accept the scanning shortcut on the Fiery. I'll try to double check my set up procedures this week and get back to you.
