Ricoh C900S Fiery Issues
  • fatfingers73
    • Feb 2013
    • 219
    Morning all,
    After some advice setting up a C900S fiery.
    First time I've set up a fiery from scratch and probably missing something obvious.
    Went into command workstation 4 setup and entered all the tcp/ip settings, but fiery server is still looping 127.0.0.1?
    I've given the copier the same details, not sure if this is needed with a fiery or not?
    Any help would be great.
    Also getting the message check copier power & connection cables. Copier is working fine.
    Have a good weekend
  • fatfingers73
    • Feb 2013
    • 219
    Re: Ricoh C900S Fiery Issues
    Ok got it working.
    LAN 2 was set to dhcp.
