4G Wireless Dongle + Separate LAN
  • CES_Imaging
    • Nov 2012
    • 65
    I've got a customer running Windows 7 Pro on his laptop at a remote construction site. There was no LAN available to put the plotter (a KIP 3000) onto, so we put in a router and used that in between the KIP and his laptop. To gain access to the internet he uses a Verizon 4G USB dongle.
    With this setup, he has two networks. The Verizon 4G one which gives him internet access, and the LAN we set up for him to connect to the KIP. If he is connected to the 4G network, he is unable to print over the LAN. Simply removing the 4G dongle does away with that problem, but the rate at which he needs to print and also use the internet makes this solution problematic. Is there a way to allow him to print to the LAN networked KIP while simultaneously being connected to the 4G network?
    Thanks!
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: 4G Wireless Dongle + Separate LAN
    It may be best to contact the 4G provider for their input. It could be that they block other connections, even if not deliberately.
    I have a similar problem at home. If I'm on my work PC connected to my company's VPN, I can't access any other PC on my home network.
    Once I get off the VPN, it all opens back up.
    On the other side, though, I frequently use the same notebook PC, tether it to the 4G connection on my phone, then connect via crossover to an MFP. I do this when I can't connect to the customer's network, and need Internet access at the same time I'm connected to the copier (some Ricoh software requires that to install properly).
    • blsquires
      • Nov 2008
      • 342
      have you tried using a crossover cable for the kip3000 and remove the router .
      • Iowatech
        Not a service manager
        • 3930
        For what it is worth, I've heard that Windows 7 doesn't require crossover cables. I only carry crossover cables, so I haven't tried that yet.
        • Shadow
          PHD in Sh!t Disturbing
          • Sep 2011
          • 455
          have you attempted to share the network connection that the KIP is on?
          give it a try and let me know how it works out.
          I had something very similar to this a while back, just can't remember what all I did to make it work.
          $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
          • CES_Imaging
            • Nov 2012
            • 65
            I think the best option would be a crossover cable. I'll try that.
            • ApeosMan
              • Nov 2009
              • 183
              If you have somehow inserted a gateway address into the NIC TCP/IP settings then remove it and see if that helps. You could also try giving the NIC a higher priority than the 4G connection and see what happens.
              How about just connecting the plotter via a USB?
              • qbert69
                • Mar 2013
                • 1152
                Have the 4G wireless dongle connected to the laptop.
                Connect the laptop ethernet port to a wired ethernet SWITCH..NOT ROUTER!
                Connect the printer/plotter to same ethernet switch.
                In network settings, bridge the 4G and ethernet by selecting both connections simultaneously and then right clicking with mouse button and choosing bridge connections.
                You MAY have to manually set the IP address on the printer/plotter to match the IP addressing schema that the 4G dongle is giving out...if it doesn't do DHCP. But you SHOULD be able to bridge connections, so that you can use both at the same time.
                If there are other people using the "network", you should be able to "share" the G4 dongle through your bridged connection and have your machine give out DHCP address through the switch (don't router to avoid ip addressing conflict) or you may have to manually set ip addresses on all devices connected--ip address and subnet mask.
                Good Luck!
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                • nmfaxman
                  • 1702
                  Install the switch or crossover cable and bridge the connections through the network and sharing center.
                  Done it a few times myself.
