Ricoh 1022/1027 scanner and fax connectivity issue.
  • Yasir Aziz
    • Feb 2015
    • 10
    Hi. dears i have Ricoh 1022 copier i was installing the machine print/scan kit so both features working properly. but after few days my customer required a fax card so i will install fax card and i m just connect the fax card machine turned on i see on screen scanner feature is hidden. but if completely disconnect fax card scan feature show on screen. i will try many times all cards connect and disconnect but nothing work i also try another machine lane print/scan ram cards all works but i m not check fax card. pleas any idea its urgent my payment was blocked. thanks in advance and sorry for my poor English.
  • sandmanmac
    • 3981
    Re: Ricoh 1022/1027 scanner and fax connectivity issue.
    Why so many posts??!
    http://www.copytechnet.com/forums/ri...fax-issue.html
