Mac MS Word
+ More Options
Posts
  • iliketui
    • May 2014
    • 48
    Mac MS Word
    My knowledge with MAC OS is very limited but am slowly picking things up.
    I have a customer using MAC OS 10.9.5 who is able to print. The customer has a Sharp MX-C301W. They have the driver installed twice, once for colour and once for black and white with B/W as default.
    The customer has a colour document which they want to print in B/W which works fine when they go File -> Print, but this customer wants to be lazy and hit the quick print button which prints any document in colour.
    So my question is how do I set the quick print button to print in B/W?
    I have done some quick research and found a procedure on setting the printing defaults to B/W through CUPS, but this hasn't made a difference.
    Another thing that frustrated me on multiple PC's was when i went File -> Print -> Presets -> Show Presets, the next window had a list of Current settings, Default settings and Last Used settings. It showed the current settings OK but when i selected Default settings or Last Used settings the application (Word or Safari) would crash.
    Any advice would be greatly appreciated.
  • habik
    • 2013
    Re: Mac MS Word
    System Preferences > Print&scanner > Default Printer (not last printer used) check the one where you have BW driver installed. Thats it.
    Firmwares HERE
    • iliketui
      • May 2014
      • 48
      Re: Mac MS Word
      Originally posted by terramobil
      Hi,
      I don't know Sharp devices but with Ricoh devices this works very well (PostScript commands for paper trays, duplex, staple and other features are the same on b/w and color devices): Is there a similar black/white device at Sharp? Use this driver for b/w printing.
      I haven't tried using another models driver. Will give it a go.
      When the customer selects file -> print, it is already on default printer.
      Just to confirm, is last used printer different to last settings used?
      • iliketui
        • May 2014
        • 48
        Re: Mac MS Word
        Hi,
        This has worked.
        I confirmed that the original B/W setup was the default printer, but was still printing in colour when the quick print button was used.
