All in one I.T. Tech software.
  • NeoMatrix
    Senior Tech.
    • 3513
    #46
    Re: All in one I.T. Tech software.
    Originally posted by allan
    i could be the perfect rat. i have run into my first problem.
    [ATTACH=CONFIG]29535[/ATTACH]
    I have to select ok 4 times in a row for it to open. Did i do something wrong?. I use W7 64bit.
    Look cool i should get the hang of it.
    I haven't tried it with WIN7. It works thats ok.
    The program uses the current directory as default and stores that in the "PROGRAMDIR" variable in the "CONFIG" tabsheet.
    The program couldn't find the ittb\box\ directory so it loaded the four default WINXP,WIN7,WIN8,OTHER toolboxs as "default.box."
    You should be able goto File|Open and load any of the above four toolbox's from the \box\ directory.
    The program builds a unique user identifier code first time it executes. This code is unique to that program instance only. You should write down the GUID number in case
    you wish to sell/rent your knowledge base toolbox to other users or your apprentice.
    The GUID is your proof of ownership.
    The four toolbox buttons WINXP,WIN7,WIN8,OTHER, are own by me they will expire in one month.
    You need to start with a blank tool set and then "save as" over the above four file names with your own GUID code signature.You can change the above 4 name in the "Config" tabsheet. Use short name so they fit on the button face.
    If you import someone elses toolbox you will be prompt with their user name and password each time you run that single toolbox set.
    • NeoMatrix
      Senior Tech.
      • 3513
      #47
      When people feel they have a good general understanding of the software, I will post a few examples of how to use the "SUBST" tabsheet programming language. You can then program your own popup menus, ip-adress, output text ,warning text, cost control,machine and file i/o text.
      Once people know how to use the "SUBSTITUTE" program sets you should be able to program the command line to suite any 3rd party software. From there you can store complex commands to a button. Just right click any button and copy the command lines to save to the current button; then save to any toolbox file.
      • NeoMatrix
        Senior Tech.
        • 3513
        #48
        Any feed back from the POC test so far fella's.
        Hint :
        How many have worked out to left click any button to populate the main command line fields , then right click a new button use it as copy any paste to duplicate the commands to the new button?
        • Iowatech
          Not a service manager
          • 3930
          #49
          invalid date.pdf
          Sorry about the .pdf, as of this very moment I am unable to upload .jpg images.
          • wseyller
            • Sep 2012
            • 1129
            #50
            I get the same issue with date errors. Windows 7, and windows 10.
            Sent from my XT1254 using Tapatalk
            • NeoMatrix
              Senior Tech.
              • 3513
              #51
              Originally posted by Iowatech
              [ATTACH]29632[/ATTACH]
              Okay yes. The date format is Australian (ddmmyy) not American.(mmddyy) That is why there's a beta test before a version release... I will have to fix that bug. All POC version of this software stop dead after december this year.
              Iowatech as test try opening a toolbox file from the \box\ directory.
              eg WINXP,WIN7,WIN8 or OTHER.BOX
              For backward compatibily the software is written using WINXP and complied using 32bit instruction code.
              I haven't got it to run on Win8.1 as yet. My enthusiasm is a tad low, I may get a chance in a week or two. I'm in a training coarse at the moment. I'm learning a complete new system.
              Thanks for the update...
              • allan
                RTFM!!
                • 5462
                #52
                Still here just a little busy. Would you mind using team viewer?
                Whatever
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  #53
                  Yes I have only recently installed Teamviewer for WIN8.1 we can give it try if you like.
                  I'm not sure how we do the audio interface on Teamview though.
                  In general I guess should stop being lazy an put together a basic help file so everyone can get the hang of it a bit quicker.
                  • Sil80s13
                    #54
                    Still need BETA testers? I work in the IT field and would love to try it out.
                    • Gabriel
                      • Jun 2006
                      • 139
                      #55
                      I can help. what information do you need from the testers (feedback)?
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        #56
                        Re: Beta tester
                        I'm holding off on more beta tester people until I finish the help file. I'm about 1/3 the way through the help file at the moment.
                        If anyone else wants to beta test let me know before I update the software download link.
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          #57
                          Help file for iT-Toolbox POC (version 1.1.1.56)
                          The file is in PDF format and about 1.5MB in size. Should be time stamped 07/07/2015.
                          See attached file.
                          • Elmo
                            • Feb 2010
                            • 541
                            #58
                            Hi
                            Would it be possible to join the beta test
                            thanks
                            I Used To Live To Fix Things Now i Fix Things To Live
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              #59
                              Okay I'll open up the beta test so that other may become beta testers. You have 24 hrs to download it.
                              The below link has an revised help file ver1.1 as well for those interested.
                              There is a save to file error in the main save function of the software, please use save-as if modifying any tool buttons.
                              I have a working version of the software for win8.1.
                              The POC version thus far doesn't do GUI scaling for laptop screens. I will have to fix that bug for my own laptop.
                              Download link for POC version (1.1.1.56) 9.75Mb timestamp 10/07/2015
                              Hightail Spaces lets you send unlimited files, of any size, to anyone. Collaborate with your team and evolve your work.
                              • NeoMatrix
                                Senior Tech.
                                • 3513
                                #60
                                If you've download the latest version of iToolbox software and want to be active in the POC test, can you PM me so I can add you to my POC/beta test email list.
                                Please post all test results here to the forum. Don't forget to proof read the help file as well.
                                Neo
