All in one I.T. Tech software.
  • NeoMatrix
    replied
    Re: All in one I.T. Tech software.
    When people feel they have a good general understanding of the software, I will post a few examples of how to use the "SUBST" tabsheet programming language. You can then program your own popup menus, ip-adress, output text ,warning text, cost control,machine and file i/o text.
    Once people know how to use the "SUBSTITUTE" program sets you should be able to program the command line to suite any 3rd party software. From there you can store complex commands to a button. Just right click any button and copy the command lines to save to the current button; then save to any toolbox file.
  • NeoMatrix
    replied
    Originally posted by allan
    i could be the perfect rat. i have run into my first problem.
    [ATTACH=CONFIG]29535[/ATTACH]
    I have to select ok 4 times in a row for it to open. Did i do something wrong?. I use W7 64bit.
    Look cool i should get the hang of it.
    I haven't tried it with WIN7. It works thats ok.
    The program uses the current directory as default and stores that in the "PROGRAMDIR" variable in the "CONFIG" tabsheet.
    The program couldn't find the ittb\box\ directory so it loaded the four default WINXP,WIN7,WIN8,OTHER toolboxs as "default.box."
    You should be able goto File|Open and load any of the above four toolbox's from the \box\ directory.
    The program builds a unique user identifier code first time it executes. This code is unique to that program instance only. You should write down the GUID number in case
    you wish to sell/rent your knowledge base toolbox to other users or your apprentice.
    The GUID is your proof of ownership.
    The four toolbox buttons WINXP,WIN7,WIN8,OTHER, are own by me they will expire in one month.
    You need to start with a blank tool set and then "save as" over the above four file names with your own GUID code signature.You can change the above 4 name in the "Config" tabsheet. Use short name so they fit on the button face.
    If you import someone elses toolbox you will be prompt with their user name and password each time you run that single toolbox set.
  • allan
    replied
  • allan
    replied
    Now i just feel left out.
  • chinxxx
    replied
    รวดเร็วก่อนใคร ระดับคุณภาพเรื่องฟุตบอล ได้ที่นี่ ฟุตบอลสด
  • NeoMatrix
    replied
    To those people who expressed interest in beta testing the IT-Toolbox software
    you should have received a download link in a PM.
    Let me know if you have problem getting the zip file to uncompress.
    I will post the MD5 here if there is any problems. The compressed file size is 7.614 MB in size dated 22-06-15 at 12:15 pm download from server.
    There is no installation procedure just drag and drop the entire directory structure any where you wish ie. HDD or USB stick.
    Neo.
  • CanonSco
    replied
    The following image are some screen shots of the POC version so far.
    I shouid be looking for a couple of POC/beta testers in a week or so.
    [ATTACH=CONFIG]29456[/ATTACH][ATTACH=CONFIG]29454[/ATTACH][ATTACH=CONFIG]29453[/ATTACH][ATTACH=CONFIG]29452[/ATTACH][ATTACH=CONFIG]29455[/ATTACH]
    Cool. I can be a test mule if needed. I work primarily on the network side of the field and would be able to use something like this in anger most days.
  • NeoMatrix
    replied
  • NeoMatrix
    replied
    Chug... chug... cha.... I've run out of steam.....
    I've been out of action for a couple of weeks with a viral infection.
    After the bad cyclone went through the local water around here has been putrid.
    According to radio reports they are trying to remove hepatitis and Ecoli bacteria out of the water supply...
    Yum... boiled water from here on...
    Not far away with a very basic POC prototype....
  • CanonSco
    replied
    Still at it.... The Enthusiasm is still going, just....
    I should have a POC out in a week or so....
    If not I will post a couple of screen shots to give people an idea of the general concept, so far.
    All ideas are welcome...
    Hope you still have enthusiasm
  • NeoMatrix
    replied
  • CanonSco
    replied
    An updated version of MFP Tools would be a winner.
    It hasn't been updated since '05.
    MFP Network Tools - Free download and software reviews - CNET Download.com
  • qbert69
    replied
    We could take note from the folks at iFixit and have an app created that gets "push" updates from a server for tips and tricks!
    iFixit is a global community of people helping each other repair things. Let's fix the world, one device at a time. Troubleshoot with experts in the Answers forum—and build your own how-to guides to share with the world. Fix your Apple and Android devices—and buy all the parts and tools needed for your DIY repair projects.
    ...something easy to navigate!...that's KEY!
    ...also this!:
    Overlook Soft
    ‎Fing has helped millions of users worldwide to understand: • Who's on my WiFi • Is someone stealing my WiFi and broadband? • Have I been hacked? Is my network secure? • Are there hidden cameras in the B&B I'm staying in? • Why has Netflix started buffering? • Is my internet provider giving me the sp…
  • NeoMatrix
    replied
    Originally posted by Gazzahos
    As stated in your previous post. This will only work on a PC. Is there anything you could set up to work on a Mac?
    For example, instructions on how to enter the CUPS screen or any support to access the CLI screen? They would be very handy to the uninitiated!
    Not as yet, a platform change could happen later on.....
  • Gazzahos
    replied
