All in one I.T. Tech software.
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    #61
    Re: All in one I.T. Tech software.
    Finally downloaded after missing the last invite
    Will get it on one of the work laptops next week and have a look. Thanks NeoMatrix.
    Can you add me to mail list?
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • NeoMatrix
      Senior Tech.
      • 3513
      #62
      [Version 1.1.2.57 ]
      Pending Update for both laptop & PC. Works with Win8.1.
      I've made provision for Win10. Can someone test it for Win10.
      [Fixes 1.1.1.56]
      Screen scaling for laptop.(Almost)
      Defaulting Op-sys buttons when install or USB drive letter changes.
      Changes to Config screen now saves on exit from screen.
      Output-to off button removed, Editor & Printer buttons now toggle on/off.
      [Notes]
      I can't get enough screen realestate for laptop screens. I may have to change the Tray and Tool button key board from a 6 x 4 Array to a 5 x 5 array. Anyone got any thoughts on the keyboard layout changes? Overall it just makes the GUI wider an smaller in height.
      • Iowatech
        Not a service manager
        • 3930
        #63
        [Notes]
        If it is not too much trouble I'd appreciate that (or maybe a scroll bar, if that is easier). Apparently the monitor I have for this box is like a laptop screen, and the bottom of the window extends below the task bar, and I can't access anything below the function button portion.
        Thanks!
        • NeoMatrix
          Senior Tech.
          • 3513
          #64
          Thanks!
          If I change the Tray-Tool button keyboard from 6x4 to 5x5 ; all your current tools box files will not load.
          That means all your current tool button configurations will be lost. You'll have to start afresh.
          I see how the 5x5 graphic user interface(GUI) looks and feels.
          My enthusiasm is a tad low. I have to get more paying jobs out the way first.
          The missus gets the sh!ts big time when I do too many luv jobs.... doh!...
          • Iowatech
            • 3930
            #65
            Take your time, your the boss here.
            This has already reminded me of an old favorite, tracert. I'd forgotten about that ever since I found the "Is It Down Right Now?" website.
            Thanks!
            • NeoMatrix
              Senior Tech.
              • 3513
              #66
              Ok Beta-Testers. Any everyone else.
              The latest ittbV11257.zip. See the below public link.
              https://www.hightail.com/download/bXBiYkJpZ2dubVZ4Tk1UQw
              The file will be available for download for the next 24hrs.
              The above version has been modified with a 5x5 keyboard and updated help.pdf ver2.0 files.
              The modified version has been optimised for laptop screens.
              There have been a few bug fixes along with extra token functions.
              I have configured the WinXP toolbox with a heap of button examples,these should get you going with your own software programming and knowledge base functions.
              Please send all correspondence here to the copytechnet forum so others can follow the progress.
              Neo.
              • NeoMatrix
                Senior Tech.
                • 3513
                #67
                Re: help.pdf ver2.0
                I found a couple of omissions and grammar mistakes.... bugger...
                I'll try an update the help file in the coming weeks........
                • Iowatech
                  • 3930
                  #68
                  I just tried this out, and now I have access to the bottom of the window. Holey buckets, there's a lot more to this than I first thought!
                  For what it is worth, I found one glaring issue on my end: when I decompressed the files to a new folder, that folder was made "Read Only". That caused all the buttons in the command window to be unassigned. Once I turned that off the buttons were restored. This might just be an issue with Win 8/10, but it might still be something to note in the help file so dopes like me know to check that.
                  Still getting the date errors, but as you said earlier that's just a regional thing.
                  Is there any other information you'd like to know about this? If so, let me know.
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    #69
                    [ver1.1.2.57]
                    1. Send a small screen shot of the date-time issue.
                    2. Read only issues is an odd one. There is a autorun.inf folder that might lock you out when loading from USB stick.
                    3. A lot more than first thought. It's not that difficult. It's just a learning curb. Once you program some buttons yourself you'll get the hang of it quickly. The CONFIG tabsheet shouldn't be easy to access, it might be causing unnecessary concern. There is a lot of hidden system options in the config that may never be used. Disregard the config for now.
                    [Known bugs]
                    There is a extra comment text bug with new USER1 file filter on open/saved dialog in the config tabsheet. Just remove the //comment text an the filter should work.
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      #70
                      When people get the iTToolbox program sorted out, I hope to get time to write specialised tools to go into the program.
                      I would like to expand on skynettos theme with communication interfaces like WIM, password an email tools.
                      I have other pressing issues for the time being....
                      I all depends on the enthusiasm ... ...
                      • Gamut
                        • 216
                        #71
                        I'd be more than keen on anything that assists in resolving PITA scan to folder/mail setups on win7.
                        And Comms with WIM sounds interesting.
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          #72
                          The WIM interface is already done. You can set up a button with an Address Dialog box and off you go.
                          If you have a copy of the software I will post the button code so you can plug it in a try it.
                          command C:\PROGRA~1\INTERN~1\iexplore.exe
                          parameter [d:a]
                          Store the above to any button an launch. An address dialog box will pop up an you can enter and IP address of an MFD.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            #73
                            Has anyone found a used for the job editor section as a personal diary for recording a history of those special fixit jobs ?
                            Your own personal knowlegde base of fixs and repairs
                            The overal job editor concept was for both manager and personal use.
                            If people prefer a personal fixit memoir diary I could add in addtional search fuctions and keyfield records to suit.
                            Yer....no,no....yer... don't care.....?
                            • Iowatech
                              • 3930
                              #74
                              Actually, I was looking at the job editor with keen interest now that I have access to it. Even though the mothership keeps track of my service calls, that looks very useful for a personal log of what I do while on the clock. (Now I just have to get off my lazy sitting muscles and use it. I promise I will.)
                              • NeoMatrix
                                Senior Tech.
                                • 3513
                                #75
                                Those using the ittoolbox.
                                A button function to google search copytechnet.com.
                                An Input dialog box[d:h] pops up and allows the user to enter search text.
                                It then loads iexplore.exe and runs the google search command line parameters.
                                You can change the command to firefox.exe or chrome.exe if you wish.
                                parameter "www.google.com/search?q=[d:h]&sitesearch=copytechnet.com&gws_rd=cr,ssl&ei=12 3"
                                If anybody has any handy button functions please share them to the forum. The best ones will
                                go into the next version of the iTToolbox program for toolbox general distribution.
                                Any button function will do. Eg. Load GoosesGuide.pdf. Load KyoceraTI-Lib.pdf, etc....
