Config Database connect?
+ More Options
Posts
  • Girwar
    • Jul 2025
    Hi,
    is there an way to gain access to the machine config database/file? Except from the usual web interface. I.E for Kyocera or Minolta.
    Thanks Gir
  • allan
    RTFM!!
    • 5462
    Re: Config Database connect?
    Why do need a function like this. The only reason i can come up with is to import settings to the next machine.
    You can export the settings to a file.
    And then there is API.
    I am not sure what Data Administrator for the BH machines does.
    Whatever
    • Girwar
      Sry i dont need it for import/export ... for that il could use the Network Print Monitor or the DatabaseAdmin.
      Ill would like to change some default parameters ... well not me ... me customers would like it.^^
      -Gir
