Scan to email
  • JVC
    • Jun 2011
    • 151
    Scan to email
    Hello
    I have been setting my customers up with either gmail or live (now outlook) accounts. I usually use gmail but when it doesn't work I have been using a live (outlook) account. Recently I have been getting a lot of calls from the customers that are set up with live accounts that scan to email is failing. The message in the log is failed smtp authentication. Does anyone know what smtp setting I should use now? Thank you in advance.
  • wseyller
    • Sep 2012
    • 1129
    Re: Scan to email
    I use gmail all time on mostly Konica Minolta and Canon. With gmail you must enable "for less sure apps" after creating the account. Use SSL port 465 or Start TLS 587.
      • 37495
      Re: Scan to email
      When using Office 365 as your email service, the default is START TLS. Many MFPs only support SSL. Even if you set port 587 it will still only use SSL and the cloud server will not accept authentication. Microsoft does allow you to set up a relay server using either SSL or port 25 for your email domain. There are some restrictions with these relay services. Depending on what you set up you could be restricted to authenticate only specified email users (i.e. your MFP email address) or send only from specified public IP addresses (i.e. your router's public address). In one of the possible settings there is a limit on the number of emails that can be sent in a 24 hour period.
      • JVC
        • Jun 2011
        • 151
        Re: Scan to email
        Thank you for the replies. I'm not sure if I explained the issue that I am having. I have set up these customers over the past few years and the scan to email has been working fine. None of these customers do a major volume of scanning. All of a sudden they all called me within a day saying the scanning has stopped working. I checked the log and they all say SMTP Authentication. Here are the settings that I have been using
        Enable SMTP Client Enabled
        Enable SSL Accept all certificates without CA
        SSL/TLS STARTTLS
        SMTP Server Address smtp.live.com
        POP Before SMTP disable
        Authentication login
        Login name email address
        Password password for the email address
        Port 587
        SMTP Client Connection Timeout 30 seconds
        The fact that a number of different clients all using live accounts have had the same issue leads me to believe that something has changed.
        Again thank you for any help.
        • Iowatech
          Not a service manager
          • 3930
          Re: Scan to email
          Could it be that they upgraded to a new version of Windows?
          Best I can tell Microsoft made some vast security changes in Windows 8, which could cause something like this.
          Still, I don't deal with issues like this very often, so this is probably wrong. Sorry.
          • Gazzahos
            • May 2014
            • 38
            Re: Scan to email
            Why use a gmail/live account only for the device?!
            Inherent in your standard practice is the fact that all there outbound scans are saved in an account. This could be viewed as a privacy/security risk. From memory I think an email was sent to live account holders to authenticate the accounts use after the change to outlook.com. Although that was in Aus over a year ago.
            If the account is the same as the customers email account, then they would see all the outbound scans and be able to clean them out of the account themselves. Are they also having problems with outbound emails from there business?
            Input the ISP SMTP server details. In Aus usually no SMTP authentication is necessary if you are on the same network as the router connected to the ISP. In this case authentication problem solved.
            • sandmanmac
              • 3981
              Re: Scan to email
              All I know is that MS has phased out @live.com. Existing accounts are apparently unaffected; However pinging smtp.live.com returns no response either, so it seems that there has been a change there too.
