Okidata 5502
  • antone
    • Oct 2014
    • 344
    Okidata 5502
    Jams trouble code 520 duplex only
    Sent from my SM-N950U using Tapatalk
  • richs
    • Nov 2008
    • 226
    Re: Okidata 5502
    Usually anytime I get jams in duplexer the whole unit needs to be replaced.You can check to see if one of the plastic bushings for the duplexer transport rollers has popped out of place .Oki does not spare any parts for the duplex unit.
    • richs
      • Nov 2008
      • 226
      Re: Okidata 5502
      Disregard last post......got confused with a mps3537.I have had the bushing pop out before but luckily found it and the clip inside of the machine.
      • scanmc
        • Mar 2015
        • 171
        Re: Okidata 5502
        I've had the same issue on a few of these units. Change out the feeder registration unit #45377801 should cure your problem
