E014-0002 within Imagepress C1
  • khattab.al.masry
    • 212
    [Error Code] E014-0002 within Imagepress C1
    Dear colleagues:
    We facing problem within our Canon imagepress C1+ that display E014-0002.
    as in service manual that there is overload with Fixing belt motor.
    I replaced Fixing belt assembly with another one error gone and machine worked as well.
  • teckat
    • 16083
    Re: E014-0002 within Imagepress C1
    Originally posted by khattab.al.masry
    Dear colleagues:
    After inspecting the Fixing Belt Assembly, it was discovered that connector J814 which is located on the Fixing Belt drive Motor M36 was not seated all the way.
    This connection did not have to be removed when taking out the Fixing Belt Assembly.
    When removing the other connectors from the Fixing Driver PCB,
    the wire harness may be pulled and the connector J814 is dislodged accidentally.
    Re-seat the connector J814 on M36 Motor Driver to resolve.
    Cleaning the Pressure Pad Cover inside the Fixing Belt Assembly and applying the correct amount of Silicone Oil (S-20; FY9-6011-000) should correct the issue.
    • khaled_abosere3@yahoo.com
      Head technical support
      • Mar 2012
      • 170
      In other case we found the following socket was broken
      Sent from my CPH2239 using Tapatalk
      • wcanonw
        • Aug 2014
        • 404
        hi dear where do you get this spare part
        FL2-2584-000 Transfer Belt, FL2-2576-000 for Canon imagePRESS C1
          • Mar 2012
          • 170
