CANON DR 9080C: Issue: pink vertical lines on scans...
  • n25an
    • 1030
    CANON DR 9080C
    Steps taken...
    1. clean image contact sensor (ccd)
    2. replace image contact sensor
    3. ran quma adjustment
    4. replaced sensor reflectors in aligning area
    5. clean white registration
    Issue still remains...
    any suggestions would be appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • kiwitech
    • Oct 2012
    • 29
    Re: CANON DR 9080C: Issue: pink vertical lines on scans...
    The machine has 2 scan sensors...front side and back side you didn't change the wrong one by mistake ...? also I have fixed many that were full of staples.
    • hidius
      • Jun 2015
      • 128
      the machine is a one pass scanner. so you have a ccd at the bottom and a ccd on the lid. if you do a double sided scan does one side have the line and the other side is clean? .. just make sure you clean both ccd
      • n25an
        • 1030
        thanks much appreciated...
