IRC 3380 E990
  • Joek1966
    • Aug 2014
    • 5
    [Error Code] IRC 3380 E990
    Hi all, one of my techs replaced the drums and ITB cleaner and is now getting an E990 error. Has to with bk lock lever, sensor blocked. Anyone seen this? Any help much appreciated.
    Re: IRC 3380 E990
    see pdf as a guide, not the best job in the world, Despite what the pdf says its more likely that ps12 is covered with toner and needs to be cleaned rather that the rack repositioned.E009-0000.pdf
    • Joek1966
      • Aug 2014
      • 5
      Re: IRC 3380 E990
      Thanks for the reply Skynet. I found the same article on Knowledge Base and sent it to the tech.
      • teckat
        • 16083
        Re: IRC 3380 E990
        First*
        Tell teck to get a long straw & fix to copier type vaccum & blow out sensor ps12.
        If doesn't work then follow pub
        • Canuck
          Tech Specialist
          • 1713
          Re: IRC 3380 E990
          I have a piece of surgical tube that goes on the end of nozzle for my vacuum. I never blow toner off a sensor...it just goes somewhere else..usually to 3 other sensors
          • teckat
            • 16083
            Re: IRC 3380 E990
            Thanks for reminder, I meant to say vaccum cleaner.
            Fixed Thought /-
