Canon imageprograf 6300
  • Gus633
    • Jun 2015
    • 42
    [Error Code] Canon imageprograf 6300
    Hi guy's,may have bought a lemon...printer has a lit up lcd screen with nothing showing.
    However after loading printer software I was able to read this error code :- 0196
    Hopefully someone might tell me that it's 'just' the lcd/board gone
    kaput? Upon powering up nothing seems to happen except the
    lit screen and then a single beep. Then nothing. I do know that the software communicates with the printer that's all. And no there are no inks installed-having to sell my 1st born to medical science to afford them....
    Any clues? Hints tips most appreciated.
  • Gus633
    • Jun 2015
    • 42
    Re: Canon imageprograf 6300
    Originally posted by teckat
    Try Re_seating the connection between the Video PCB and the DC Controller
    E196-0000 Error in Engine Controller*
    A data communication error occurred in the Engine Controller PCB.
    Replace the Engine Controller PCB.
    E196-2000 Error in Main Controller Communication*
    Access to the Flash ROM in the Main Controller failed.
    Look into your connections on pcb's
    Hi Teckat,thanks for the reply. Checked out the connections found
    a loose one reseated. (I'll tag the connection later on) Hoped that
    was it. Carried on and looked at the pcb boards. The wee ribbon cable socket looks the worse for wear so looking to replace that.
    Wiggled it with power on not much happened except the screen went off,managed to get it back on-still no signs of life in the printer itself-nothing seems to initialise and the screen's still lit and blank.
    Is this a main board issue then? The real expensive one?
    I'll repair the lcd board 1st and take it from there....
    • teckat
      • 16083
      Sorry, Disregard that first post of E196 (removed> was for 6100)
      can u make out the full error line message > may not be below E CODES
      Correct E196 for imagePROGRAF
      iPF6350/6300
      E196-4040 Checksum error (when execute the firmware update)
      Execute firmware update or replace the main controller PCB.
      E196-4041 Flash memory erase error (when execute the firmware update)
      E196-4042 Flash memory write error (when execute the firmware update)
      E196-4045 EEPROM read/write error (controller part)
      Replace the main controller PCB.
      E196-404C Serial number mismatch between main controller PCB and maintenance cartridge
      ROM PCB.
      Execute PCB replacement mode or replace the main controller PCB.
      E196-404D Machine ID mismatch between main controller PCB and maintenance cartridge
      ROM PCB.
      E196-404E EEPROM read/write error (engine part) Replace the main controller PCB.
      E196-4043 Memory error (when execute the firmware update)
      E196-4044 Firmware size error (when execute the firmware update)
      • Gus633
        • Jun 2015
        • 42
        iPF6350/6300
        ROM PCB.
        ROM PCB.
        Hi again,
        well I'm about to update the firmware using the L Printer tool...except I cannot get it to find the .jdl file that I've put in the data folder....mind you I think it's for the other firmware update tool (From Canon's site!) Started on this hours ago,been looking through most of the posts on here for help/guidance........
        • teckat
          • 16083
          How to download System Software for a Large Format Printer.
          Answer :
          This knowledge base is a general guide on how to down load firmware that is needed to flash/upgrade system software on the Large format printers. There are two ways to upgrade the system software on the Large format printer.
          One is using the FUT, Firmware Upgrade Tool and the other is using the L Printer Tool.
          The FUT is designed so the customer can flash or upgrade the printer on there own. The printer must be in normal operating conditions to use the FUT. This article does not cover using the FUT to upgrade the printer.
          The second method is using the L Printer Tool. This is what the technicians can use when the printer is having problems.
          The requirements for the L Printer Tool are:
          1. The print driver must be installed on the PC or Laptop that is connected to the printer.
          2. The FUT file must be downloaded and unzipped on the PC or Laptop that is connected to the printer.
          3. The PC or Laptop needs to connect to the Printer, via the existing network configuration the customer is already using or a cross over Cat. 5 cable or a USB 2.0 cable.
          Note: USB is simpler to use, (No TCP/IP configuration is needed).
          To flash/upgrade system software on the Large format printers the FUT file for the model must be downloaded. This FUT program contains the firmware to flash the printer. The L Printer tool needs this firmware to flash the printer. Below is a link to the iPF 755 model firmware.
          http://www.usa.canon.com/cusa/support/office/large_format_printers/imageprograf
          _ipf755/imageprograf_ipf755#DriversAndSoftware
          In the image below the OS (Operating System) of the PC or laptop needs to be selected. Use the red drop down arrow key to display the various Operating systems to choose from.
          After choosing the Operating System scroll down to the Firmware section of the page. In this area select the FUT file to download. In this example select the one for [Windows]. iPF750755-FUT-WIN-115.exe
          The file download security warning screen will now appear. Select [Save] from this dialog box to download the file.
          Next select where to save the file on the HDD. The best method would be to create a folder and save the file in the newly created folder. In this example the folder is named iPF755.
          Select save and the file will start to download.
          The file that was just downloaded is in a zipped format and needs to be unzipped or extracted so it can be used.
          Double click on the zipped file and the Win Zip Self-Extractor will open as in the image below. Now select [OK].
          Note: If the Win Zip Self Extractor does not open this file Win Zip may not be installed on your PC or laptop. Older versions of Win Zip can be obtained as a free download. Google Win zip, download it and install it on your PC or laptop.
          After the file has been unzipped the Firmware update tool is ready to install and use or the firmware files are ready to be selected and used by the L Printer Tool.
          When the L Printer tool is used the program needs to select the path to the [.jdl] file that is actually the firmware file.
          In the image below the path to the [.jdl] file is shown.
          • Gus633
            • Jun 2015
            • 42
            Answer :
            Cheers,I didn't get the FUT! Only the jdl file....oops twas wondering
            why the file wasn't getting picked up in the data folder everything else was going well. Will post later on if the 3600 comes to life!
            Again many thanks for your help,much appreciated.
            • teckat
              • 16083
              https://www.dropbox.com/s/688p9sh5ld0d8zf/L_Printer_Service_Tool_v1.80_32Bit.zip?dl=0
              https://www.dropbox.com/s/hg5ol4inb8nzbb8/L_Printer_Service_Tool_v1.80_64Bit.zip?dl=0
              L_Printer_Tool_Instructions.pdf
              • Gus633
                • Jun 2015
                • 42
                Hi Techat,
                well I've followed all the firmware download procedure....still running into issues.
                I've downloaded the Firmware Update tool :- Fut-Win-2400 (32) Unzipped and ran setup.
                Let it source the latest firmware (1.25) Didn't expect it to update the printer due to it being in error and not in receive update mode.. But when you go to the data folder there is no .jdl file at all?
                Nothing like the one showing in the data folder in the 'how to file' you uploaded for me.
                So off I popped to Canon's support page and downloaded the latest update for Win XP 32. So good,so,so far away...?
                This file downloads as this :- Wl46bmux_firmware0125_6300_6350.jdl,again not like the one in the how to file or the L
                Printer Tool TP08 publication 'iPF755V0115.jdl' or anything like it appears anywhere....am I missing something/doing it wrong somehow?
                Tried using the firmware as downloaded but the transfer button stays grayed out on the L Printer Tool,well it sort of flashes on and off if you will....so that was a bust.
                I've never known an update be so infuriating to accomplish.....the programs are there,the update file is there.....and yet
                a solid brick wall. Am I doing something daft? I thought I was quite intelligent until this.
                I've even removed both programs via windows and there own uninstall programs and tried again,same result.
                So removed them again and then went into regedit to make sure they were,indeed gone. Re-installed both (Update first,then ran it,let it search for the latest update,which again found as Ver 1.25,again no .jdl file)
                Then installed L Printer Tool and went to search for the file....nada. I'm puzzled as the 'how to' file seem's simple!?
                Oh,by the way that connection on the main board that was not connected properly,was J2512,all the rest were seated.
                Anyhoo,I'm off to delete/uninstall everything again then re-download things and try again....been at this for a goodly while now......jings I need help.
                • Gus633
                  • Jun 2015
                  • 42
                  Hi Techat,
                  well I forgot about this I pulled from the printer....the error code you were asking for was indeed
                  E196-404E,so I guess it's a new motherboard/main(?) board for the wee beasty instead of trying to do the firmware update? Below is the bad news I guess?
                  Printer Info Ink Info
                  MC: 0% PC:0% C:0% MBK:0% Y:0% M:0% PM:0%
                  R:0% G:0% B:0% PGY:0% GY:0% BK:0%
                  System Info
                  RAM : 384MB
                  Error Log 1:E196-404E 2:E196-404E 3:E196-404E 4:E196-404E 5:E196-404E
                  Canon imagePROGRAF iPF6300 Status Print
                  Firm:01.23 Boot:01.24 MIT(DBF):6.00 MIT(DB):1.10
                  S/N:AAFC0575 Date:2015/08/14
                  HEAD LOT NUMBER
                  LOT L:762B08Q1a R:862B23 1a
                  PARTS STATUS
                  COUNTER Wia1:OK Wib1:OK CR1:OK CR2:OK CR3:OK CR4:OK CR5:OK
                  SP1:OK PG1:OK HMa1:OK PL1:OK PS1:OK Mi1:OK MS1:OK CT1:OK
                  Or do you think If I can get the jdl file to try and update....nothing to lose.
                  Cheer's in advance,
                  Gus.
                  • teckat
                    • 16083
                    Hi Techat,
                    System Info
                    RAM : 384MB
                    HEAD LOT NUMBER
                    PARTS STATUS
                    Cheer's in advance,
                    Gus.
                    Just make sure it's nor a harness/connection issue
                    First try to flash the firmware to resolve the issue.
                    After flashing the firmware, initialize the error in service mode. [INITIALIZE] > [ERROR].
                    If the problem remains, replace the Main Controller PCB
                    Replacing the main controller PCB
                    1) Turn off the power and disconnect the power plug.
                    2) Replace the main controller PCB.
                    3) Reconnect the power plug and turn on the power while pressing the [Load] and [Navigate] keys. (Start the printer in PCB replacement mode.)
                    4) Release the key, but not before making sure that "Initializing" appears on the display. (The message lamp lights when printer enters PCB replacement mode.)
                    5) Wait until "REPLACE MODE" appears on the display.
                    6) Select CPU BOARD and press the [OK] key.
                    7) Turn off the power, but not before making sure that "Power off" appears on the display.
                    8) Turn on the power.
                    9) Check the firmware version. If the firmware is not the latest version, upgrade the firmware to the latest version.
                    Firmware Update Tool
                    Use of the following tools allows you to update the firmware of the main controller incorporated in the printer.
                    - imagePROGRAF Firmware Update Tool
                    - L Printer Service Tool
                    1. imagePROGRAF Firmware Update Tool
                    imagePROGRAF Firmware Update Tool is the same as that for user.
                    Procedure:
                    1) Start imagePROGRAF Firmware Update Tool.
                    2) Place the printer in the online mode.
                    3) Transfer the firmware data to the printer according to the instructions shown on the display.
                    4) The data shown on the LCD on the operation panel changes and the firmware is updated automatically.
                    5) When firmware update is completed, the printer will start again.
                    File transfer route: USB, network
                    2. L Printer Service Tool
                    Procedure:
                    1) Start L Printer Service Tool.
                    3) Specify the firmware file(.jdl) and then transfer it.
                    • Gus633
                      • Jun 2015
                      • 42
                      Hi Techat,
                      so the jdl file is the correct one that I'm trying to use?
                      If so where/why won't it show in the data folder? As per the instructions or pictures.
                      I've taken the board out so all the connections will be reseated and I'll try again....
                      Once again,cheers for the help!
                      Regards Gus.
                      • teckat
                        • 16083
                        Hi Techat,
                        Regards Gus.
                        did u try and select VIEW ALL (HIDDEN) FILES
                        what is your PC
                        Windows ver. ?
                        Close all programs
                        • Open Folder Options by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
                        • Click the View tab.
                        • Under Advanced settings, click Show hidden files and folders, and then click OK.
                        Now go in a look for the .jdl
                        • Gus633
                          • Jun 2015
                          • 42
                          Hi Techat,
                          It's Win XP Service pack 3 and 32 (Need that for most of my flight dims!) I was going to try that the night about hidden files but I thought if they (Canon) Are supplying the update why on earth make them hidden? So I'll give it a go,boards back in resting my knees,bite to eat then we'll see....fingers crossed!
                          • teckat
                            • 16083
                            Hi Techat,
                            it's not Canons fault if hidden/ it's a Windows thing
                            ?? silly thought
                            are u following the Canon default download locations for both downloads/
                            • Gus633
                              • Jun 2015
                              • 42
                              I did originally,then followed your directions,except for the L Printer Tool file,that's on the default should it be somewhere else?
