HDD data clear
  • dwhelp
    • Mar 2015
    • 3
    [Misc] HDD data clear
    I have a Canon Ir8095 need to clear data off the hard drive for the customer. I don't work on Canon. what do I do.
  • teckat
    • 16083
    Re: HDD data clear
    “Initialize all Data/Settings”
    Procedure to Initialize All Data/Settings
    (WARNING: DATA WILL BE ERASED. Before using the 'Initialize All Data/Settings' feature, make sure that the data you are erasing is no longer necessary or is backed up.
    This procedure will not erase documents or data stored outside of the imageRUNNER hard disk drive.)
    1. On the imageRUNNER Device (see above for supported devices), press the Additional Functions key, then, select the System Settings button (if assigned, you will need to enter the administrator password to
    access this menu); then select Initialize All Data/ Settings. (The default overwrite setting is once with null data. If an optional security kit is installed, the administrator can set the number of overwrites to up
    to three times with random data within service mode prior to performing the procedure.)
    When prompted to confirm if you want to proceed with this procedure, press YES. (It may take up to 30 minutes to initialize the hard disk and overwrite the user partition)
    2. After the Hard Disk is initialized, press the main power switch to OFF.
    *This will not effect the Firmware > it will remain intact
