IR 3045 IR 4570 jam 0A01 0A05 Power on / Start up jam
  • Guest
    [Jamming] IR 3045 IR 4570 jam 0A01 0A05 Power on / Start up jam
    Every time i Turn on my IR 3045 it automatically pick up a paper from Tray 1 and jam while on Canon Startup Screen
    Error: 0A01 0A05
    Even after i restart it, it picks up a single sheet of paper again and jam (Paper is on the pre-reg sensor and not yet reached the fuser / Fixing unit)
    No print job interrupted before.
    See Jam No. 1,2,4,5,6
    Im not sure what triggers it to pickup paper on tray 1 on startup.
    i Set the First tray to FLSC since its giving me persistent 2nd copy jam on Tray 1 with LTR paper, But it works when it set it up to LTR-R.
  • ernesto
    • Oct 2011
    • 430
    Re: IR 3045 IR 4570 jam 0A01 0A05 Power on / Start up jam
    Maybe the solenoid that is in the the paper pick up assembly 1 is sticky....
    • Guest
      Will Check solenoid and give you an update.
      Got this from other thread: http://www.copytechnet.com/forums/ca...ight-door.html
      • Guest
        Hello again,
        Yes it was the solenoid.
        There's a worn foam that turns sticky and delays paper out.
        But.. it works for 50 uninterrupted pages, After i try another copy it gives the same thing.
        Here how its jammed:
        Here's the error:
        Thanks in advance.
        • Guest
          Any one who know how to stop this copier from pulling a paper on the 1st tray every time i turned it on?
          • gkalman2004
            • 157
            Hi everybody
            I know it is older post but i have the same issue 0A01 with one almost new IR2530i, i changed all the sensors from the pick up assembly and i change the clutch's beetween them without any results.
            I receive 0A01 error (jam) every time when i power on the unit and also when it come back from standby.
            In the rest, after the first jam it just work fine without any error.
            I also rewrite the firmware but the error remain the same.canondef.pdf
            Can anybody give an advice ?
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5018
              Hi,
              Did you remove the sticky foam from cassette solenoid?
              Also remove all others sticky dumpers from copier especialy on pre-registration sensor flag.
              • gkalman2004
                • 157
                Originally posted by zoraldinho
                Hi,
                [ATTACH=CONFIG]42102[/ATTACH]
                Yes i remove it, but i not check the pre-registration sensor flag because i did not know she had also there one .
                Thank you, i will check tomorow also this tip.
                • zoraldinho
                  • Mar 2008
                  • 5018
                  Dumper is on the back of the pre-regist. main body guide (FL2-0330-000)
                  • BIMAN CHANDRA NATH
                    • Apr 2011
                    • 42
                    u can change the 1st cassette pick up assembly or inter change with the 2nd cassette and see the result.
                    • kstan268
                      • Apr 2012
                      • 85
                      you need to stick a peace of plastic sheet after you remove the sticky dampper
