Using a Booklet Maker with IRADVC5030 w/ ImagePass B-1
  • RHodg57
    • Dec 2013
    • 191
    Customer is trying to run booklets with the Booklet Finisher C-1. I am using the PCL6 driver for the ImagePass B-1 and
    for whatever reason I cannot get it to create the booklets. With all the booklet settings set it wants to sent the booklet to
    the second finisher tray. I have went through every setting I can find and no luck. I switched the driver over from the UFR2
    because when it would create the booklet the print on the pages were not coming out the right size. I checked the printer settings
    at the copier under Functions>Printer and found the Booklet Finisher setting was off. I turned it on. No change.
  • disam
    • Sep 2008
    • 64
    Re: Using a Booklet Maker with IRADVC5030 w/ ImagePass B-1
    Hi
    there is no Problem, but witch Driver version have you installed, the last one is Version 21.52
    and with this Settings here
    and for booklet you can use only one tray
    • RHodg57
      • Dec 2013
      • 191
      Customer is using MS Publisher. I set the booklet settings to use Application Settings instead of
      driver settings or device settings. Now it works.
