Another ImagePass B-1 question
  • RHodg57
    • Dec 2013
    • 191
    A customer uses and IT service that connects remotely to their computers and printers.
    I installed an ImagePass B-1 unit on their IRADVC5030 copier and the IT people say they cannot access
    the device from their remote location. They can access it by going into one of the customers
    computers. Is there anything on the B-1 I can change to make that happen?
  • teckat
    • 16083
    Re: Another ImagePass B-1 question
    How to Enable the Remote Operator Kit for the imageRUNNER ADVANCE?
    There are a few things needed to use the Remote Operator's Software Kit.
    1. Verify the Remote Operators Kit is installed.
    2. Enable the Remote Operators Kit.
    1. First, you will need to activate the Remote Operator's Kit by entering the License Key or installing the .lic file via the RUI.
    To verify the Remote Operator's Kit is installed, press Counter Check, press Check Device Configuration, scroll to the Options and look for the Remote Operator's Software.
    2. Next, you will need to enable the Remote Operators Kit.
    1. Press Settings/Registration.
    2. If Management Settings is greyed out, then Login as System Manager.
    3. Press Log In, Enter in System Manager ID and Pin. Press Log In.
    4. Press Management Settings > License/Other > Remote Operation Settings, make sure set to On. If you want to use a password, enter a pw and press OK, then Close.
    Make sure to reboot the imageRUNNER ADVANCE for this to take effect.
    • RHodg57
      • Dec 2013
      • 191
      They want to access it like they do the other printers in the office. Not to print to it but to be able to change
      settings from RUI. Again they access every computer and printer in the office and can access RUI on the
      ImagePass from the computers in the office. They just can't from their computer far away.
      The software kit you mention, as I understand it, is for disabled people to be able to copy from their
      computer screen. These are IT people, I guess it seems to me that it shouldn't be a problem as the
      ImagePass is just basically a printer.
      • teckat
        • 16083
        Remote UI for the imageRUNNER ADVANCE 5000 series
        The new Remote User Interface (RUI) available with imageRUNNER ADVANCE models has been enhanced for centralized device and user management. Enhancements include:
        1. Completely re-designed to be similar with device user interface for greater accessibility and usability
        2. Application menu to add/delete device functions and MEAP applications in a single interface 3. Authentication menus for Dept ID, SSO-H, Access Management System (AMS), and Advanced Box activation and user management 4. Restart Device button for remote restart of device
        To access the copier's RUI through the Fiery in one step: 1. Open a Web Browser and type in the following URL:
        http://:8080/
        Newer imagePASS Controllers, ColorPASS GX100, and imagePRESS Server Controllers:
        Enter the IP address or name of the Fiery
        Press Launch Remote UI for access to the imageRUNNER ADVANCE.
        To access it directly, enter http://IPaddressof imagePASS:8000/rps in the web browser address bar.
        For example, http://192.168.1.1:8000/rps
