Right Wiper damaged?
  • methogod
    • Dec 2008
    • 921
    No matter what i do this wiper wanted to pop up and out of the clips...
    Should i look to replace wiper asembly? or entire system?
    really not a canon guy have a small shop and just picked up a ipf8300 for indoor photo printing.....
    would love to get a tech out here to help... and get me on the right track...
    i am a konica tech, and familiar with larger HP machines/Seiko type....
    thanks,
    • 16083
    Re: Right Wiper damaged?
    thanks,
    Encore Business Systems
    611 Commerce Drive
    Upper Marlboro MD 20774
    1-800-249-2523
    Encore Business Systems, Inc Canon Image Runner Advance Maryland
    • methogod
      • Dec 2008
      • 921
      Geez, thanks for referral....
      wanted a little help in here first before spending money....
      THe last step i took before moving on to something i was more familiar with was buying 12 in carts. And pulling the right wiper unit.
      WHat i need is where are the glycerin tanks on the parts book?
      And the wipers assembly be ordered as a part or only as the entire pump/drain....
      thanks,
      mike
        • 16083
        thanks,
        mike
        ALL ARE INCLUSIVE ~~~~~~~~~~~~~~~~~~~~~~
        online for between 260.00/ 350.00
        Purge Unit===QM3-7018-000
        see attach pdf
        After replacing the purge unit
        The information about the number of cleanings arises in the purge unit. After replacing the purge unit, select [INITIALIZE] > [PURGE] in the service mode to
        initialize (clear) the information about the number of cleanings.
        Wipers
        The wipers are driven by the purge motor to wipe the six trains of nozzles in the nozzle assembly in the printhead simultaneously.
        A pair of wiper blades are in position to ensure wiping performance. The wiping operation operates on a slide wiping basis, sliding the wiper blades via wiper cams
        through the normal rotation normal of the purge motor.
        Wiping is executed by the wiper blades moving at a constant speed to the front of the printer after the end of a print or suction operation.
        A wiper blade set perpendicularly to the head wipes the entire face of the printhead, followed by a narrower blade wiping the nozzle assembly.
        The wiper blades are cleaned before they are replaced at the wiping position after wiping to preserve wiping performance.
        Wiper blade cleaning is carried out by scraping off the inks that have been wiped off from the head with an ink scraper linked to the maintenance cartridge, then
        wiping the blades with a blade cleaner.
        Wet wiping is carried out for added wiping removal performance, whereby the wiper blades are moistened with glycerin as they are pressed against an absorber
        impregnated with glycerin.
        *The quantity of glycerin used is managed by counting the number of times the wiper blades have been pressed against the absorber.
        When this count falls to equal any of the following values, either a replacement warning (continued print available) or replacement required indication (service call
        error) is issued.
        Display --------------------------Times
        Replacement warning indication---71,250 times
        Service calls---------------------75,000 times
        Don't never loosen or remove a/the red screw, because normal operation and print can't be done if it is loosened or removed.
        • methogod
          • Dec 2008
          • 921
          see the issue, ordered parts.
          but now it keeps saying wont / cant feed paper....
          as we try to enter service mode....
