Irc5045 duplex jams
  • romang
    • Aug 2011
    • 72
    Irc5045 duplex jams
    Hi all, Im not a canon tech so dont know about this model. It jams when attempting to duplex everytime. Single copies are good. It exits the fuser then starts going into the right door reverse area then just stops. I got into service mode and it shows ps39 delay jam. Not sure of the paper path and how to test sensor or which one. Any ideas?
  • ernesto
    • Oct 2011
    • 430
    Re: Irc5045 duplex jams
    Is the paper jam wrinkled?
    • teckat
      • 16083
      jam code 010A refers to a delay jam to Reverse Sensor PS39.
      add an extra spring wrap to the actuator on sensor PS39
      Make sure the paper sensor roller, FB6-7002-000, is not missing.
      See below and Parts Catalog Figure 812, Item 3.
      When a sensor is not changing state or to verify if a sensor is changing state use of the I/O modes may be used to troubleshoot such issues.
      Check PS39 in service mode > COPIER > IO > PSENSOR > DCON > P005 bit 12.
      When paper is removed from area > If P005 Bit 12 shows a 1 which > it means the sensor is blocked.
      Try re-seating connectors on the Pick UP Driver PCB UN2 and cutting wire ties to PS39 .
      • romang
        • Aug 2011
        • 72
        Thanks for the replies. No the paper is not wrinkled it just stops not hitting anything or z folds.. I will try teckat suggestion sometime this week. Thanks again.
        • romang
          • Aug 2011
          • 72
          Tested sensor ps39 was not changing state swapped with sensor that isnt being used on exit area. Problem fixed . Thanks for the help!
          • teckat
            • 16083
            ole.jpg WELCOME
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              Well done.
              I was once carrying 5 sets of these sensors.
              3 require replacing usually for 010A / 010C jams in 3 way unit. Occasionally it presents itself with a jam that cant be cleared without a power off / on
              They were replaced with modified ones. Which then fail after a while.
              Yes, I am a nerd.
              Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
              • romang
                • Aug 2011
                • 72
                Sharp had the same issue with sensors failing , probably same manufacturer as canon.
                Thanks for the info!
                • Zela
                  • Mar 2014
                  • 25
                  Clean all rollers including registration, check the feed wheel in the paper tray.
                  It is installed on the machine finisher?
                  Control gears in fixation, the fixation of the film.
                  Is the leading edge of the paper is damaged?
