This IR C4080 will print on heave stock perfect on the first print, if you print 5 copies, the last 4 have a ghosting problem (please see picture). Also, the print is clean when you send 1 print each 20 seconds apart. Any ideas on how to be able to print multiple copies with one command without this ghosting issue?
This only happens on heavy stock, no issues on plain.
