error E202-001
  • mpj
    • Jul 2025
    [Error Code] error E202-001
    please help me with fixing the error code above..i have disconneted the flexible cable and reconnected it and swapped the scanner hp sensor
  • hsrmms
    • Dec 2014
    • 69
    Re: error E202-001
    If you are not technician do not touch any thing under the glass HI VOLTAGE could harm you.
    This error for home position scanning lamp.
    The scanner home position sensor (PS400) is faulty. The scanner motor (M400) is faulty. The reader controller PCB is faulty.
