IR2200 jam code 0112
  • adel_nathan
    • Jul 2011
    • 103
    [Jamming] IR2200 jam code 0112
    hi every body
    i have a problem facing me in more than 5 photocopy machines model IR2200
    that ,when i make two sided , the jam occurs when paper pass in 2nd side
    before entering fixing unit , its' edge curl up after leaving drum and jamming
    the code is 0112
    i try to clean and change eliminator , doesn't help
    clean transfer roller , doesn't help
    please , please , please help me
    thanks
  • ernesto
    • Oct 2011
    • 430
    Re: IR2200 jam code 0112
    It seems humidity in the paper a4r mode or dry paper solves the problem....
    • adel_nathan
      • Jul 2011
      • 103
      Thanks for fast replay
      A4r is passed correctly
      I change to anther good type of paper
      But A4 is also jamed
      Is there any setting in service mode can be modified
      to solve this proble?
      Thanks again ,am waiting your advice
      • ernesto
        • Oct 2011
        • 430
        When you make a copy for one side...is it curle or plane ....if the answer is Curle the problem is the humidity for this reason the paper is stuck before unit fixing on second side mode...
