IRC4080 Color change after drum replacement
  • w0179651
    • Jul 2015
    • 24
    After replacing the yellow drum, the cyan turned more green and magenta tuned more orange. I did a p-print and re set the RCON and DC-Con. Still the same issue. Please see before pg 10 and after pg 10 pdf, any advice?
    Aug31ColorError.pdf
    The Magenta drum is brand new.
    I think I'll try trial and error via this post: http://www.copytechnet.com/forums/ca...-overtone.html
  • vigour
    • Aug 2010
    • 1038
    Re: IRC4080 Color change after drum replacement
    Do your Autogradation
    • w0179651
      • Jul 2015
      • 24
      I have been, how many times should I do it. I've been changing the PASCAL settings too.
      • w0179651
        • Jul 2015
        • 24
        So, I used Autogradation and the color settings to somewhat get the colors back to normal. Still not perfect. When print black text, its good, when printing black in pictures, its dark green. Reds are looking orange.
