Canon IPF750 hardware error 03130031-2F26
    replied
    Re: Canon IPF750 hardware error 03130031-2F26
    Slant adjustment handle*
    The tilting of the head is adjusted with the lever.
    Chapter 2_ 2-22 in manual.
    Chapter 1
    For fine adjust slant of rules lines.
    Read your manual, it explains your operations with description.
  • Roverius
    replied
    Originally posted by Roverius
    I checked the purge unit (not removed yet) and there seems to be some cotainer holding a liquid.
    [ATTACH=CONFIG]30586[/ATTACH]
    The container is the black square box on top of the unit.
    So, is this normal that there is some liquid inside. It looks like its allmost full.
    Regards,
    Roverius
    I found some video and there was also some liquid in the container. So, i guess this would be normal.
    Hence my question on the blue handle.
  • Roverius
    replied
    Regards,
    Roverius
  • Roverius
    replied
    Still waiting for Canon tech but i have in the meantime a question.
    WHat does the blue handle on the carriage do. If i move this, i dont see any moving parts.
    The axis underneath turns probably with a concentric wheel that moves the head up or down.
    Moving the blue handle does not make any change in movement of the axis.
    How is this determined that the engine sees how to adjust the printhead acording to the setting of the blue handle?
    Also would it be advisable to reflow the main board?
  • Roverius
    replied
    Originally posted by teckat
    that's why it pays to call a Canon Authorized Field Service Company if available in your area--
    checkers cost about 50.00us
    Thank you for the information.
    i do really appriciate this.
    In the meantime i have contacted a Canon service agent and will see what it will cost to examine the printer.
    I will update here with the information later.
    Thanks a lot to those who did their effort to help me out on this issue.
    Regards,
    Roverius
    replied
    It seems you need 2 of those FCC Checkers to perform the test.
    Is there a way to test it whit 1 FCC Checker?
  • Roverius
    replied
    Micro cracks can cause numerous problems and intermittent random error codes.
    Using the Flexible Flat Cable Checker (FCC Checker) would be a good idea to find out about the condition of the Flex Cable.
    [ATTACH]30509[/ATTACH]
    replied
    Question:
    Is it possible that there is a problem with the ribbon cables?
    When i pull out the cables from the mainboard, i get exactly the same problem and error.
    Probably microcracks on the bended places?
    (see previous post for movie)
    I have read that someone had the same error and replaced the cables wich solved the problem.
    Flexible Flat Cable Checker IPF Series.pdf
  • Roverius
    replied
    Question:
    replied
    Thanks, have one already
    Make sure to follow all directions on part changes👌
  • Roverius
    replied
    update to link for manual
  • Roverius
    replied
    Does your front cover have Service MANUAL listed ?
    above is a example page from the manual
    replied
    Thanks for the link.
    However i have somekind of servicemanual.
    Is this a different one like the one from scribd?
    Regards,
    Roverius
  • Roverius
    replied
    FREE ONLINE GOOGLE SEARCH > iPF750 MANUAL
    https://www.scribd.com/doc/77953298/...Service-Manual
    Regards,
    Roverius
    replied
    Thank you SAZ911 for the specifique information.
    I have already disassembled the carriage unit already to check for problems.
    With you're information i will check the relay board.
    Thank you very much for you're support, i really appreciate this.
    Regards,
    Roverius
    CANON imagePROGRAF iPF750 / iPF755 service MANUAL, REV. 0 Canon Inc. This manual has been issued by Canon Inc. For qualified persons to learn technical theory, installation, maintenance, and repair of products. There may be information in this manual that does not apply to your locality.
