Canon IR7105 blank area on 1 half, only first page after sitting for a while
  • skibum
    Independent Service Tech
    • 234
    I have a IR7105 that has missing print as if the dev roller is not turning at first or a short in the coronas. It only happens for the first page if the machine has not been run in hours. Anyone seen this on this machine.
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon IR7105 blank area on 1 half, only first page after sitting for a while
    send a sample
    Distinguished road makes you jewel in rough
    • skibum
      • 234
      This is the sample. It happens almost always everyday first print. see sample print of this first page, then after the first page it is fine. IR7105 PRINT ISSUE_20150904080634.pdf
      Thanks!!
      • GasMask
        • Sep 2015
        • 15
        hi
        have you changed the Corona's?
        what happens if you do a wire clean?
        does the deletion location change?
        what happens on a very long run, is there any deletions or fade out?
        • tinnyjay
          • Oct 2009
          • 663
          This is the sample. It happens almost always everyday first print. see sample print of this first page, then after the first page it is fine. [ATTACH]30531[/ATTACH]
          Thanks!!
          Maybe sleeping for a long time causes toner melt on developer mag roller but it looks also like a transfer/separation problem.
          First i would suggest SM-Copier-Functions-Install and clean all coronas with a cloth and alcoohol.
          "Who loves the roses,must also bear thumbs"
          • skibum
            • 234
            All the coronas have been changed and the toner on dev roller looks good and uniform.
            When running a long run (200+ pages) it works fine after the first page when this issue occurs. The sample; note the drop out in the first 1 1/2" for about an 1" then it comes back. This sample is only of a half page of print to begin with. It is with the first half of the page that the drop out occurs for the 1" blank area.
            • mramlawi
              • Jul 2011
              • 838
              It could be laser problem , or theres humodity ,always this happen but we change the transfer corona , you can also try to make toner supply
              • Canuck
                Tech Specialist
                • 1713
                Re-wire the transfer/sep......
                • GasMask
                  • Sep 2015
                  • 15
                  Hi having put the question to my team,
                  Laser as mentioned by another engineer above.
                  Bias contacts
                  Ap kit would cover drum.
                  Even though its ok on a long run its dropping charge somewhere.
