Canon ImageRunner Advance 4051 scan
  • Thom
    • Jul 2014
    • 22
    I have a Canon IRA 4051machine that needs the small ADF glass. I only have one of these machines and it keeps getting a "clean the feeder(?)" error for the customer. I haven't seen the error, but the glass is pretty worn thru the scan area, so thought it needs replaced. Does anyone have the part number for it and the mylar guides (if they are separate)? Or, any other ideas? Thanks in advance!
    Thom
  • teckat
    • 16083
    Re: Canon ImageRunner Advance 4051 scan
    Thom
    Feed guide (dust collection tape) ?
    FL3-2860-000
    -Peel off the release paper of the new feed guide.
    -Attach the new feed guide.
    NOTE:
    When replacing the consumable parts, be sure to clear the parts counter.
    (Lv1.COPIER > COUNTER > DRBL-2 > LNT-TAPE1 )
    or Stream Reading Glass in (reader unit) ?
    FL3-3206-000/ GLASS, READER
    • dan7777
      • Dec 2012
      • 680
      Thom
      FL3-3206-000 Reader glass
      For sensivity level I think it is copier>option>img-rdr>DFDST1 and L2. Turn to minimum 125. I like to turn mine to 80. Teach customer how to clean scan glass. You can turn it off in regular settings mode. Does not need glass until it causes lines but good idea to replace if you think it is causeing line. It has never worked well and we turn ours down on setup.
