IR2000 says add toner
  • tinfox
    • 317
    Hi,
    I have a new customer that I am going out to see tomorrow and she says they added toner but the machine still says add toner.
    Is there anything I should look for?
    (I don't normally work on Canons)
    TIA
    tinfox
  • maks
    • May 2008
    • 75
    ir 200 toner indication
    maybe the customer forgot to remove the plastic strip on the toner cartridge..
    • montana
      • Aug 2008
      • 392
      Hi.you can check the developing assembly.&the contacts.or the toner cartridge expired.
      have a good luck
