e000025-0001 for IR5050
  • latif.abd
    • Aug 2025
    [Error Code] e000025-0001 for IR5050
    Please help me i've got an error e00025-0001 for my IR5050,I tried browsing the web about this error and majority of them are saying that this is a toner motor issue. but i've replaced the toner motor, it doesn't change, remain the same, it doesn't work. pleas help me. what should I do to fix this error problem?
  • vigour
    • Aug 2010
    • 1038
    Re: e000025-0001 for IR5050
    The motor will blow the DC controller sometimes.
    Read these posts
    http://www.copytechnet.com/forums/canon/93525-canon-ir5075-toner-supply-problem.html
    http://www.copytechnet.com/forums/ca...highlight=e025
    • GasMask
      • Sep 2015
      • 15
      hi
      have you replaced the sub hopper drive essembly?
      • dan7777
        • Dec 2012
        • 680
        Originally posted by vigour
        This will probably fix the machine. You can buy a fuse for the dc controller. They look like resisters. Or take a fuse off another board. You just go to the controller and ohm out the fuse. The motor shorts and blows the fuse on the board. About 50% of mine made it. A lot cheaper than a board but still a takes a while. The pdf shows the fuse number. E025-0001 by replacing fk2-0813-000 motor and fu15 when necessary on the dc controller.
