Code error E804-0006 on iPC 800
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi to everybody !
    I have this fault on iPC 800: code error E804-0006.
    The code appears occasionally....
    I cleaned the fan and various cables.
    And I also checked its operation: the fan runs!
    Suggestions ?
  • MKalnins
    • Sep 2012
    • 7
    Re: Code error E804-0006 on iPC 800
    Have you tried clearing DCON?
    • khattab.al.masry
      • 212
      Hi dear:
      we faced the same issue and solved by replacing fixing heat fan.
      i hope to be helpful for you.
