Canon irc2220
  • hsrmms
    • Dec 2014
    • 69
    Canon irc2220
    Customer had Canon irc2220 can't pick up paper from Tray 1 I cleaned the spearted roller, Changed PAPER PICK-UP ASSEMBLY FM0-1658-000 but still not pick up the paper from Tray 1.
    I can see the paper left up to the proper level.
    any ides.
    Regards
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon irc2220
    I think there is a bulletin on the shaft that drives the feed roller isn't long enough which doesn't give drive causing it to jam
    Sent from my iPad using Tapatalk
    • hsrmms
      • Dec 2014
      • 69
      Re: Canon irc2220
      Can you kindly proved me with this bulletin.
      Regards
      • mosey1100
        • Mar 2009
        • 143
        Re: Canon irc2220
        Regards
        Here is the bulletin.
        • hsrmms
          • Dec 2014
          • 69
          Re: Canon irc2220
          Thank you i already replaced the pick up unit with new one and still not pick up paper i can see the separation roller moving but can not pick up paper from tray 1.
          Regards
