Only LED green light on iRC 2380.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Another strange problem...
    iRC 2380: LCD of the control panel, dark, Led green, on, printer engine that moves but not print and can't makes copies.
    I cleaned the RAM pack, PCB boot and the contacts of the various PCBs present in MAIN.
    Nothing!
    The printer does not respond!
    What do you advise me to do?
    Thank....
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: Only LED green light on iRC 2380.
    Inspect supply and outlet voltage.Reset memory again.Do you have any progres bar start? Can you quickly drop in service mode to check any errors? Try with disconnected kits like fax.
    Use sst and reinstall HDD.
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      The LCD panel it's completely dark ! The MAIN PCB not responds with RUI..... The logic of machine appears dead....
      • dj_beirut
        • Aug 2018
        • 14
        did you ever find a solution to this problem? i have the same issue.
          this thread is over 3 years old.
          • aAandy
            • Apr 2012
            • 370
            and was probably a dead HDD
