does anyone know how to reset the drum on a 6012. it does not have a u3 to reset. only lets me have a u1 or u2 also reset machine through tp 3 & 4 didnt help
it has a new drum
it has a new drum
you cant disconnect the counter pcb because it will give you an error. Find an np 7130 that needs a drum unit put in an np 6012 drum unit instead. remove the counter pcb and put it in yours. np7130 does not use a counter but uses the same drum unit except for cosmetic difference. cannot use a 7130 in a 6012 because of counter.
