Canon ir-advc9280 pro
  • mramlawi
    • Jul 2011
    • 838
    Hi to all,
    im working on pro series 9280 the machine was working very good but the yellow drum looks bad the blade not cleaning it ,so i had an old drum assembly with the primary roller i removed the parts and installed it to the one it workin in after i finished i turend the machine on and fastly error code e0025-0110 display ,then i turend all the parts back (drum and the primary) thought the code occur when i exhanged ,and then i turend it on again the error occur also,i got lost cos on the service manual said theres somthing on the hooper or patch sensor want to clean ,but i didnt work at all at the hooper side!!
    what i also noticed that when i turend the machine on all the toner bottles door are opened .
    not only that the error changed also from e0025-0110 to 0210. Also the machine from time to time gove e197-2000.
    please help thanks.
    Distinguished road makes you jewel in rough
  • vigour
    • Aug 2010
    • 1038
    Re: Canon ir-advc9280 pro
    YOU HAVE broken gears in the yellow and magenta hoppers. Either change the gears or the hoppers. same amount of work involved. They just break whenever
    • mramlawi
      • Jul 2011
      • 838
      Thank you for your help,after checking all the gears in all the hooper there was nothing ,i changed the dc pcb and the machine is perfectly work .
      • teckat
        • 16083
        Point to note_🍺
        24yrs in service
        Changed a DC PCB about 5\6 times
        8 of 10 times a DC PCB issue is a connection \ or wire tie issue\ or pinched wire.
        • dan7777
          • Dec 2012
          • 680
          Hi to all,
          please help thanks.
          I have a 7260 that has E197-2000 codes. The front right connector and rear connector get toner build up and need to be changed. Try contact cleaner first and air. The right front drawer connector is not too hard but the right rear one is and the left rear one takes two people or one smarter than me. The left rear one gave different codes for the fuser. It got smashed when a piece of paper got caught in it and it was slammed shut. We have seen the E197-2000 code on our 9280 also. This 7260 has a couple milion on it. Glad you got the other problem fixed as I was unsure about it. Change the connectors but don't worry about the wire harness that comes with it.
          • mramlawi
            • Jul 2011
            • 838
            Originally posted by teckat
            Point to note_🍺
            24yrs in service
            thanks again ,yea you are right i wonder how this Dc PCb fail ,what i conclude that theres a 2 connectors located on the right side for the primary corona and for the pre transfer one of it was pinched that what was leting the machine open all the hoopers doors when i turned it on .i taped it and its working now in a very good condition .
