adv 6055
  • roho
    • Mar 2009
    • 844
    [Misc] adv 6055
    Got a real doozy, went to an advanced machine for a dadf problem, that was no big issue, however....I went to check the device over and cannot open the fixing feeder tray at all. The lock handle moves, but must not be disengaging. How do I go about releasing this, I've had this before on the older image runners, but not the advance. I need to release the tray before I can see what's gone wrong. Has anyone had this issue, how did you go about releasing the tray? Thanks !
  • dan7777
    • Dec 2012
    • 680
    Re: adv 6055
    Have not had the issue but on other advance we have had bent parts (shafts) on new installs. I think when you turn the handle there is a white plastic piece that locks and unlocks at the very end of the shaft in the back. You could try and go to the back of the machine and see if you can see it. Had one fall off on a IRA8105. Have had others get loose. There is a screw holding it on you can barely reach with the drawer open. Look at figure 330 item 34 in the parts manual. I think we order that part but only replace the end. It may be loose and you only have to tighten it up.
    • GasMask
      • Sep 2015
      • 15
      Re: adv 6055
      Hi.. you can get to it by removing deck 2 tray.
      Its not straight forward though however with a little patience and proding you may release the
      Main 1 bed...
      • Canuck
        Tech Specialist
        • 1713
        Re: adv 6055
        New block is metal. Canon modified it....easy to change
        • roho
          • Mar 2009
          • 844
          Re: adv 6055
          Thanks for the help. I was able to release it from the front, then I've tightened up the block, which I'll replace with a new one. Thanks again.
