imagerunner 2202
  • montana
    • Aug 2008
    • 392
    imagerunner 2202
    hi...i installed anew dadf for canon imagerunner 2202..it is working ok but when i make copy on the dadf giving me warning message to clean tha dadf glass because it is dirty..?? how to disable this message please....thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: imagerunner 2202
    http://www.copytechnet.com/forums/ca...tha+dadf+glass
    • montana
      • Aug 2008
      • 392
      thank you for reply...but iam talking about canon imagerunner 2202...i think it is different
      • zoraldinho
        • Mar 2008
        • 5007
        2. Scan test ((2) SCAN TEST)
        Used to adjust contact sensor output and the position at which a document fed from the ADF is scanned.
        1) Enter service mode.
        Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
        2) Press the operation panel arrow keys to show "TEST MODE."
        3) Press the OK key.
        To exit test mode, press the user mode key to return to standby mode.
