Have been trying to fix above code without success. Read through an old post but info on the fix wasn't reported.
The condition is that the finisher output tray moves up not exactly to home position. Stapler head moves to the rear and stops then comes up with the E0540-0005. Work done so far; S14 sensor replaced, entire tray replaced afterwards, finisher controller replace no joy, gripper replaced and finally 3 sensors in gripper area swapped from a working MFD all without success. What should be the next thing to check, please advise any known fix.
